Noise coming from power steering
Old Jul 25, 2004
sffree's Avatar
sffree is an unknown quantity at this point
is it normal for the steering wheel to make 'squealing' noises? I guess it's only noticeable when it's hot out.. or if the car's been sitting in the sun....
Old Jul 26, 2004
clownprince's Avatar
Ricerus Maximus
when's the last time you checked your belts? That's probably what is making the noise.
Old Jul 26, 2004
PunkingCivic's Avatar
I need TP for my bunghole
When I had that noise it was actually the Altenator going bad. I thought it was the power steering to.
There was a service bulletin where they stated that the belt tension was to tight and causing the interal bearing to to go bad.
It was a $350 fix at the dealer for the part and labor. Plus a coupon for service work over a hundred dollors.
Take it to the dealer. They look at it for free.
Old Jul 26, 2004
sffree's Avatar
What?! are you sure? It only happens when I turn the steering wheel when it's hot out or if the car has been sitting in the sun.. other than that.. it's fine...
Old Jul 26, 2004
zen_master's Avatar
hmmm
damn, i got the same problem.......is it actually that bad??
i though it's only the plastic sleeve surrounding the steering wheels!
did you guys mis-understood his problem? the squicky noise was heard inside the cabin, not on the engine compartment.
Old Jul 26, 2004
sffree's Avatar
yes.. thank you.. it's inside the cabin .. and well it's not that bad.. but my car was parked under a parking structure and it still did it.. usually i've only heard it when the car's been sitting in the sun...but in light of all the work i've done (lowering etc.)I want to make sure nothings f*d up..
Old Jul 26, 2004
sffree's Avatar
why isn't my sig working
Old Jul 26, 2004
sffree's Avatar
btw.. if it is the alternator or something in the engine compartment.. would it be obvious to tell? I just had the car fully inspected during an oil change 1 wk ago.. I'm sure they would've seen something that severe
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
moorebl
Aug 29, 2015 08:39 PM
trellex
May 24, 2015 04:39 PM
anddrrey
May 11, 2015 02:30 PM
bsmiley
Apr 27, 2015 01:27 PM
