CEL Check Engine Light on after intake install
Old Sep 11, 2003
cdmx's Avatar
Well ive got this funky intake, it looks like the iceman but pretty much its a really thick intake.
Here the story:
In order to install the thing i had to relocate the fuse box closer to the firewall its mounted vertically now. And for the huge intake to fit i had to move around the fuel wires a bit, There's one coming from the firewall and its covered with some black mesh (anyone know what im talking about?) well this one made a click when I pulled it down too far by mistake. Thats all i can think of thats making the CEL light on..Oh also before this i had the fuse box too low and it was interfering with the trassmission and it was hard to put it in reverse, 3rd, 4th, and 5th but that is fixed. Now I dont really know why the CEL is on. Any tips? Do i have to take it to honda.....I have to do a whole lot of **** if i have to take it back to honda...
Old Sep 11, 2003
cdmx's Avatar
the intake is huge, could the mass air flow be causing the CEL to turn on??
Can someone give me some troubleshooting to find out what the problem is? Ask me any questions that may help you help me...thanks guys (ive tried reseting the ECU, that didn 't work)
Old Sep 11, 2003
cdmx's Avatar
here is a pic
Name:	simota intake.jpg
Old Sep 11, 2003
Jeff's Avatar
Jeff is an unknown quantity at this point
If i was you, I would ditch the intake and buy an aem! You shouldnt have to go through that much trouble just to install an intake.
jeff
Old Sep 11, 2003
CiViCLiZeD714's Avatar
what about the sensor? did you plug it in?
Old Sep 11, 2003
cdmx's Avatar
Its plugged in
Old Sep 11, 2003
2k2civic's Avatar
You said fuel wire, were you talking about a fuel hose. Maybe you broke a vapor return line and thats why your throwing a check light. See if you can get someone to check your ECU for what code it's throwing. The honda dealer may or may not do it for you, otherwise your gonna have to find a shop which will be nice enough to scan the code for free or real cheap.
Old Sep 11, 2003
cdmx's Avatar
Yes fuel hose, but my car seems to run fine(atleast i think), will it still be running fine with a broken vapor return line?
Old Sep 11, 2003
2k2civic's Avatar
Not exactly sure, I'm thinking it will.....does anyone here know the answer to that one for sure?
Old Sep 11, 2003
FattyMcJ's Avatar
Addicted to the Twisties!
Originally posted by cdmx
here is a pic
that thing is HUGE!!! lol
Old Sep 11, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
yo reset the light first.. then see if it goes on.. then work from there.
Old Sep 11, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
lol that's huge dude ...
well ... make sure the o2 sensor is plugged in ... reset your ecu?
Old Sep 11, 2003
clownprince's Avatar
Ricerus Maximus
I believe you're thinking about the Maintnence Required light. Try disconnecting your battery for 30 minutes and then taking a drive that is at least 15 miles. After 20 ignition cycles (however long that is) the ECU will reset and check again. If this doesn't work then you will have to get it checked by someone with a scanner. Check all of your sensors again to make sure you didn't leave any unplugged. I did this several times when I had my stock airbox on and was showing people the throttle body bypass but after it would come on I would just be like **** and plug it back in. Before the end of the day it would go off.
Old Sep 11, 2003
cdmx's Avatar
ok thanks guys, i left the neg battery terminal off for about 40 min now...im going to go see if it will stay off now and ill drive it around. Thanks for your help.
Old Sep 11, 2003
cdmx's Avatar
*fixed, it was a loose IAT sensor wire. Thanks for the help
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
bahena08
Apr 11, 2015 05:09 PM
