Electrical Post information/questions/Issues about Electric parts here.
Weird alarm issues
Old 10 Hours Ago
k_a4_denw's Avatar
k_a4_denw is an unknown quantity at this point
Weird alarm issues
I'm likely going to be buying a 2010 Honda Civic from my teacher for $300, and the reason he's letting it go is mainly because of these weird electrical issues he's having, which I wanna get an idea about before diving in.
He said when he bought the car 8 years ago, the car had a parasitic draw, which caused the battery to die, so he pulled a fuse, which he said "Without that fuse, a lot of things don't work including the radio, using the buttons on my car key to unlock/lock the door, and probably some other things." I have a suspicion that the fuse was #27 in the cabin fuse box (the HAC or something?), because that fuse is still gone.
He said recently the car had some cooling issues or something (I suspect either the thermostat or radiator, from what he said), and he took it to a shop to get it fixed. When he got the car back, the big electrical issues began. Basically, the car alarm goes off as soon as any door is opened or when the key is turned. He's unable to stop it with the key or any button and has to wait for it to cycle to stop, so even after the car starts and drives it continues. The car runs and drives fine, but the battery dies now and has to be jumped every time. Also, now the passenger window has stopped working apparently.
He suspected the car had an aftermarket alarm installed, and when I went to briefly check the car out in person, I saw a bunch of non-stock wiring in the cabin fuse box relay unit assembly. He's been removing fuse #12 in the engine bay fuse box to stop the horn when the alarm goes off, but he's unable to drive the car with that fuse removed (it starts but won't go into drive).
I'm guessing the major issues the car's having now have to do with whatever the mechanics did when fixing the cooling issue, could it be a ground or something?
And either way, I'd probably try to remove whatever aftermarket system's been installed (unless it's possibly salvageable).
The thing is, this is my first "project car" I guess. I have a 2012 Audi A4 which is my first car, and I've done some stuff like replacing fuel injectors and installing coilovers, but obviously nothing electrical. So I really am not too familiar with the electrical and wiring aspects of cars. But I'm hoping this is relatively simple, especially with this being a civic.
When I checked out the car, I was only able to get some quick photos of under the dash, and I saw that the wires going into the connectors directly under the top 3 relays were messed with and spliced into. I also saw some unplugged wires lying on the ground, which had labels on them (I didn't get a chance to look closer), which looked like they might possibly be part of an aftermarket kit, but again, I'm not too familiar with this stuff.
I attached the photos I took of under the dash. If anyone can make sense of this, I'd greatly appreciate it.
Is this normal on a stock car? Or could it possibly be part of a security system
Is this normal on a stock car? Or could it possibly be part of a security system. The "Enter code" message on the center screen.
This was the fuse I think might be the one he pulled out when he first got the car.
Last edited by k_a4_denw; 10 Hours Ago at 03:27 AM. Reason: Wanted to clarify a detail.
Old 8 Hours Ago
Colin42's Avatar
Re: Weird alarm issues
Stock honda radios need a code entered for them to work after they've been disconnected, lost power, etc. Should be written in the owners manual, or in something in the glovebox.
but your plan on making the wiring stock is a good place to start, double check before you cut anything
Arnie
Sep 30, 2017 05:00 PM
Laura Loveland
Mar 3, 2016 09:06 PM
Colombian4Lyf
Aug 8, 2005 01:05 AM
bluestreak
Aug 3, 2005 06:43 AM
Asphyxiate
Mar 3, 2005 12:45 PM
