Electrical Post information/questions/Issues about Electric parts here.
Brake Lights Not Working
Old Oct 6, 2024
phoneticsoft's Avatar
phoneticsoft is an unknown quantity at this point
On my 2006 Civic hybrid, the brake lights have stopped working. However, the third brake light in the rear window DOES work. I was pretty sure it wasn’t the fuse since all the brake lights would probably go out, but I checked it anyway, and the fuse is fine. I also connected my multimeter to one of the bulb sockets and there is no voltage getting to the bulb. So my problem is somewhere in between. Are there other components in this circuit or have I definitely got a wiring issue?
Also—and this may be completely unrelated—the cruise control button on the steering wheel has stopped working. In other words, I press the button down while driving at highway speeds, but the button won’t stay down. The cruise control light comes on when I hold the button down, but goes off immediately when I release. So the only way I can use Cruise control is if I hold the button down. Like I said, that may be unrelated, but I include it here in case since I know the cruise control is disengaged when I tap the brakes so those systems are interconnected.
Thanks in advance for any advice!
Old Oct 7, 2024
BrotatoChip's Avatar
Super Moderator
Re: Brake Lights Not Working
I don't have schematics for the Hybrid but I like to think they'd be the same for brake lights. The non-hybrid schematics show all three bulbs fed from the same source and grounding at the same place.
Old Oct 7, 2024
Thanks BrotatoChip. So in that circuit there's obviously the switch at the brake pedal that turns the brake lights on/off. I wouldn't think that's the problem because, again, the 3rd brake light works. What else is in the circuit that could possibly be failing? I think I read that some Hondas have a brake failure sensor to trigger a warning light on the dash? Do these Civics have that and could it be related?
Old Oct 7, 2024
Super Moderator
They all share power/ground. If the third brake light is working but not the others:
-Cut/damaged wires/terminals somewhere between the splice and the taillight connector.
-Both are burnt out and your meter just didn't measure voltage properly?
quartermilecame
Electronics
Jun 23, 2021 04:05 PM
Stefanos
Jan 7, 2019 07:13 AM
ntgarwood
Jun 20, 2012 10:01 AM
trikky74
May 24, 2012 10:49 PM
rodrj145
Dec 11, 2011 02:50 PM
