Electrical Post information/questions/Issues about Electric parts here.
Electrical Issue [solved]
Old Oct 20, 2023
Sniffum's Avatar
Sniffum is an unknown quantity at this point
Hello everyone,
I am new to this forum. I am having a big issue with my 2008 Honda Civic LX Sedan. I put in a aftermarket Alpine iLX-W650 radio and a auto-vox backup camera. I disconnected the negative battery terminal before starting this project. Proceeded with the install, got everything done, reconnected the battery and started the car, everything worked great so I was like success. Pulled my car out of the garage where I work and parked it. Shut the car off and went inside to check up on any repair that came in. About 5 minutes later I went out to start my car and nothing. If the car started it died a few seconds later; additional symptoms are: 1) car will not come out of park, 2) window will not go up, 3) no idiot lights illuminate, 4) reverse light don't work. I am at a complete loss of what could have happened. I have a feeling some how the immobilizer triggered and is not allowing thing to function properly. Any help would be greatly appreciated.
Thanks,
Dennis G.
Old Oct 20, 2023
BrotatoChip's Avatar
Super Moderator
re: Electrical Issue [solved]
The immobilizer only disables spark and fuel, otherwise the car would function normally. Easiest thing to check first to unplug the radio, see if all the issues go away.
Old Oct 20, 2023
Sniffum's Avatar
Thank you, makes sense. I took the new radio out and put the factory radio back in and nothing changes.
Old Oct 20, 2023
Super Moderator
You will need to check fuses now. Under-hood box and under-dash box. Are you able to check the battery voltage with a meter?
Old Oct 20, 2023
Sniffum's Avatar
I have not checked the battery. Checking the fuses between writing up quotes for cars.
Old Oct 20, 2023
Sniffum's Avatar
Replaced battery and still no change.
Old Oct 20, 2023
Colin42's Avatar
Recheck your wiring
Old Oct 20, 2023
Super Moderator
Still need to check fuses...
Old Oct 20, 2023
Sniffum's Avatar
Checked the fuses under dash, some fuses don't have power in either ignition position. I need to write down the fuse position number and cross it over to the fuse box under the hood. Starting to make some head way. .
Old Oct 20, 2023
Super Moderator
Service manual for the 2006 is below, should be accurate for the 2008. You can look up where each fuse is getting power from. Quite a few seem to come from fuse 2 (50/80A) in the under-hood fuse box.
Schematics:
http://civic.hondafitjazz.com/manual2.html
Old Oct 20, 2023
Sniffum's Avatar
Thank you very much for the web site.
Old Oct 23, 2023
Sniffum's Avatar
After looking at all the fuses. The fuse block under the hood, I have NO power to fuse #23. Any ideas where to start looking would be appreciated. I personally am think a relay. Thanks.
Old Oct 23, 2023
Super Moderator
Have you replaced the fuse? Even with a blown fuse you should have power on one side of it.
Old Oct 23, 2023
Sniffum's Avatar
Yes replaced it, and no power on either side.
Old Oct 23, 2023
Super Moderator
Fuse 23 does power the radio. I would bet your replacement fuse instantly blew. Unplug the radio then try again.
Old Oct 25, 2023
Sniffum's Avatar
Hello everyone,
Update on my 2008 Civic electrical issue. This case has been solved, thanks to everyone that helped out on this issue. It was something so stupid and simple that over looked because i was so frustrated that i couldn't figure out what was. Fuse #10 in the under dash fuse box had power on one side but not the other. Overlooked and didn't click in my melon.
Thanks again.
Old Oct 25, 2023
Re: Electrical Issue [solved]
glad you found it and thanks for feedback!
philLV
Electrical
Apr 12, 2023 06:12 AM
mudhenFUF
Aug 21, 2013 09:37 AM
