Buzzing noise when I try to start the car (electrical, i think) [solved]
Old Feb 11, 2011
plba1126's Avatar
plba1126 is an unknown quantity at this point
I have a 2006 civic and for the past several months there has been a buzzing noise whenever I turn the ignition. It's been sporadic for the first few months but now it happens pretty much every time I try to start it and my car will not start.
The buzz is located in the dashboard above my left knee when i'm in the driver seat.
When i would turn the key slowly it would start, but now it just buzzes
I tried replacing the starter cut relay but the problem is still buzzes and the car still wont start.
My friend said it might be the starter solenoid, but I don't know how to check.
Can anyone help please?
Old Feb 11, 2011
CraigW's Avatar
re: Buzzing noise when I try to start the car (electrical, i think) [solved]
Take off the lower left cover with the coin pocket, and when the buzzing occurs reach down and grasp the under dash fuse box and see if you can feel any vibration while buzzing is occuring.
Old Feb 11, 2011
plba1126's Avatar
Yeah it's buzzing and vibrating where the starter cut relay is. I didn't feel any vibration anywhere else.
Old Feb 12, 2011
CraigW's Avatar
What transmission ?? If it is an auto try to get it into N and see if it still buzzes when attempting.
Old Feb 12, 2011
plba1126's Avatar
Yeah I just tried that and it does the same thing.
Old Feb 13, 2011
CraigW's Avatar
From what I can see the starter cut relay is provided power to one side of it's coil and the other side of coil is provided a ground when the transmission range switch is in park or neutral positions (allowing the starter to only engage in P or N positions) You may have a poor connection in the coils circuit(could be voltage source or ground path) causing the buzzing (relay rapidly switching on/off)
If you want the info I have from the factory manual I can put some together for you.
let me know.
Old Feb 14, 2011
plba1126's Avatar
Hey that would be great! Thanks Craig!
Old Feb 14, 2011
CraigW's Avatar
I looked around at the 8th gen site and did not have much luck.
I will work on the information, PM with an e-mail address.
Old Apr 26, 2012
Erin Y's Avatar
Erin Y is an unknown quantity at this point
Hi Craig, I have the same issue with the fuse box buzzing. Any way you could send me the same info that you provided the person on this thread?
https://www.civicforums.com/forums/1...l-i-think.html
Thanks so much!!!!
Old Apr 26, 2012
CraigW's Avatar
Have you looked around on the 8th gen Civic site ?? There are a couple of videos for a no start situation, but nothing on buzzing from under dash.
Are the dash indicators coming on when key turned to II ??
The 8th gens have problems with the battery terminals making poor connections over time, you may check those.
Old May 2, 2012
plba1126's Avatar
Thanks so much!!!!
Hi Erin,
My problem turned out to be an ignition switch that needed to be replaced. If you have the same problem, it's a super easy fix. Hope that helps!
Old Feb 4, 2023
Sexileomama's Avatar
Sexileomama
Sexileomama is an unknown quantity at this point
Originally Posted by plba1126
Hi Erin,
Thank You!! I have this same problem 🤦‍♀️
jetski76
Apr 3, 2021 10:59 PM
slamtank
Aug 17, 2004 11:31 PM
Metallica454
May 11, 2004 11:20 AM
checkmate79
General
Sep 18, 2002 10:45 PM
Mex
Sep 16, 2002 12:24 PM
