Electrical Post information/questions/Issues about Electric parts here.
2008 Civic turn signal relay replacement
Old May 15, 2023
ibeLa1's Avatar
ibeLa1 is an unknown quantity at this point
Exclamation 2008 Civic turn signal relay replacement
I am trying to locate the relay for the turn signal/hazard relay. The right front and back turn signals are blinking fast, all lights are working though. When the hazards are on they blink normally. Someone said it could be the relay but I can not find it under the hood or in the car's fuse area. Is it behind the cluster on a 2008? Any help would be very grateful! Thank You!
Old May 17, 2023
BrotatoChip's Avatar
Super Moderator
Re: 2008 Civic turn signal relay replacement
There is no relay that you can replace. It's all controlled by the MICU. Did you replace any bulbs recently? Flashing fast means it sees a low load on the circuit.
e-iam
Electrical
Oct 27, 2020 10:36 AM
Single73
Dec 2, 2012 08:02 AM
SenorAlejandro
Electrical DIY
Sep 3, 2012 01:07 PM
sharpsh00ter
Jun 20, 2011 06:39 PM
Colombian4Lyf
Oct 24, 2006 10:54 PM
