Turn signals
Old Jan 27, 2010
sharpsh00ter's Avatar
sharpsh00ter is an unknown quantity at this point
Turn signals
A week ago I began having problems with my turn signals for my 2005 Civic EX 2 door. While sitting at a light, they would just turn off. I was told it was either a flasher or a relay. I found what appears to be my relay but I have Bo idea where a flasher is, much less how to determine which it is aside from replacing one at a time.
Any help is appreciated.
Old Jan 27, 2010
CraigW's Avatar
Re: Turn signals
The flasher relay is located in the under dash fuse box. It is held in by plastic clips on sides.
It is relay but also has electronics inside.
Have you tried the flashers to see if they stop also ??
Old Jan 27, 2010
Re: Turn signals
Yeah the hazard flashers don't work either. I found the relay, it was a bitch to get out lol. AutoZone sold me a flasher (Blazer FL-34) but I don't know where
to install it, much less if it will fix the problem.
Old Jan 27, 2010
CraigW's Avatar
Re: Turn signals
If you got the right part they should be almost identical to each other.
All the components are contained inside the single flasher relay unit.
Old Jun 20, 2011
joe joe's Avatar
joe joe is an unknown quantity at this point
Re: Turn signals
I'm having the same problem sharp shooter.
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
wawacito
May 14, 2002 07:33 PM
my2k1vic
Jan 8, 2002 08:31 PM
