Electrical Post information/questions/Issues about Electric parts here.
Dashboard dims when I turn on the lights [solved]
Old Mar 11, 2023
extramild's Avatar
extramild is an unknown quantity at this point
Hi folks,
A couple of days ago the garage replaced the clutch on my 200Km 2008 1.4 ltr Civic. Since then when I turn the headlights on the dashboard dims. When I turn the headlights off the dashboard goes back to normal.
My question is - Is this a setting they enabled or do I need a new battery or something?
Regards
John
Old Mar 11, 2023
FRSam's Avatar
Click Here
re: Dashboard dims when I turn on the lights [solved]
That’s been a standard function on cars for several decades now.
The general assumption is that the headlights are turned on when it’s dark out, and fully bright dash lights are distracting.
It can be adjusted by twisting one of the two buttons coming out of the gauge cluster.
Old Mar 11, 2023
extramild's Avatar
Old Mar 11, 2023
check if grounds tight in place
Old Mar 11, 2023
Colin42's Avatar
Normal, instructions on how to adjust are in the owners manual
Old Mar 11, 2023
FRSam's Avatar
Click Here
Originally Posted by extramild
Perhaps you didn't notice before or the previous brightness setting was set to maximum so there was no difference, but it has been a feature in pretty much every car since at least the late 80s.
You'd just have to turn the lights up again.
Old Mar 14, 2023
extramild's Avatar
- thanks for that - you were correct, it turn out the **** on the left hand side of the dashboard that I have never touched adjucts the brightness of the dash lights. The garage had turned it to its dimmest setting. Thanks again.
Old Mar 14, 2023
extramild's Avatar
Cheers - you are correct. I just never noticed that setting before.
Old Mar 14, 2023
extramild's Avatar
Turns out their is a **** on the dash that adjusts the brightness that I never noticed. The guys in the garage must have turned it down to almost zero for some reason. No need to go messing with electrics - thank God - thanks for your help.
Jbatalla
Feb 7, 2015 04:15 PM
What_It_Do
Jul 18, 2014 07:45 PM
gregsmi
Jul 6, 2010 07:32 AM
Rage0598
19
Mar 16, 2009 11:23 AM
ZZCIVIC
Dec 28, 2001 12:33 PM
