Electrical Post information/questions/Issues about Electric parts here.
Help! A chain of warnings. Where to begin?
Old Sep 4, 2022
Imanuel's Avatar
Imanuel is an unknown quantity at this point
​​​​​​ Civic 1.8 2010
It started with check engine light. A few minutes later the VSA light come too.
I feel the car is heavy in the start of drive, but he simply works well...
I went to the garage who checked the computer and said there was a problem with the gearbox sensor (0720 Countershaft SPD Sensor Circuit Malfunction) . He sent the results to a gear mechanical man and in the meantime I was driving. Apparently the gear man is still busy, but in the meantime I noticed that the green light indicator next to the letter D on the dashboard was flashing. In addition, the power steering light came on (The steering wheel really got hard). Than i recognize the speedometer did not show the speed but remained at 0.
during 2days the transition works well...
Today while driving he stopped changing gears, and stayed in first gear.
The question is if it is possible that all these faults happened together, or if there is only one malfunction that causes a chain reaction. And maybe the problem in the electrical system in general
Where to begin?
Imanuel
post Scriptum. I saw a video of someone who had some of the symptoms and he solved it by replacing fuses... Maybe it's all about bad fuse?
Old Sep 5, 2022
Re: Help! A chain of warnings. Where to begin?
low electrical power plays havoc with electronics and tends to light up a Christmas tree in the dash (we parrot the same thing a couple times a month for these cars).
though your is the second I hear impacting the transmission
VSA/EPS usually is among the codes.
what is causing the issue is up to you to find out...
Old Sep 5, 2022
Imanuel's Avatar
Thanks for the answer.
1. In my case It's not only about indicator, but it's about the systems nit working.
2. What the solution. Can you direct me to the thread about the problem?
And thanks again
Tracecross30
Jul 11, 2019 08:27 AM
cyprosoft
Nov 12, 2018 01:33 PM
bbailey2288
Dec 5, 2010 09:29 PM
devil_e_yes
Feb 6, 2010 04:34 PM
witty83
Oct 16, 2009 01:26 AM
