Electrical Post information/questions/Issues about Electric parts here.
Honda Civic Locked up
Old Jun 5, 2022
Treb1's Avatar
Treb1 is an unknown quantity at this point
I own a 2012 Honda Civic Ex. 1.8 L L4 SOHC 16V Engine. Every so often when I start this car it is hard to start. But just before it does start all the lights ( the lights that indicate things, like engine, transmission etc.) come on on the dashboard then the steering wheel locks and so does the gear shift which wont move out of the park position. But the engine is running!!! I have to wait 10 15 minutes then the car starts right up and is operable however the lights on the dashboard stay on but eventually turn off and everything runs the way it should. Anyone else ever have this happen ???
Albert O.
Old Jun 5, 2022
Colin42's Avatar
Re: Honda Civic Locked up
Check the battery connections
Old Jun 16, 2022
Treb1's Avatar
I checked the battery cables and they look fine. What else could it be??
Albert O.
Old Jun 16, 2022
you are not getting enough electrical power. (voltage fluctuations cause havoc on electronics and are the signs for electrical storage/supply/control problems).
which of them is... need your work to solve...
did you remove/re-tighten battery connections?
Did you check if not damage to the cables?
after that, did you check if battery is holding power? Or if alternator is charging?
etc, etc, etc
Old Jun 16, 2022
Treb1's Avatar
Actually I just looked at the battery connections but I will check damage and retighten the connections and see if that helps. Thanks
Albert O.
Old Jun 16, 2022
FRSam's Avatar
Click Here
This is what Colin meant. A visual inspection will rarely yield anything.
Battery terminals wear out over time. It's not uncommon for them to need replacing or come loose.
Old Jun 26, 2022
Treb1's Avatar
This wire is under the air filter housing.
I traced this positive battery terminal to this wire that is frayed and a small portion of the wire is exposed. Might this be the cause of the problem I am having with my car??
Old Jun 26, 2022
Treb1's Avatar
Any body know what this wire is called. It looks like it has those slide in snap type of connectors.
Old Jun 26, 2022
very small, not likely cause, just check if properly connected and use electrical tape to isolate frayed wires from metallic parts of car.
have you checked battery/charging system?
If you are not familiar, car part stores can check it for you
Old Jun 26, 2022
Treb1's Avatar
Ok, Thanks that will be my next step !!!
Albert O>
qadirshah7
Suspension
Mar 6, 2022 10:17 PM
__GalaxyWolf__
Aug 4, 2021 07:37 AM
Dolphin Sashimi
Dec 12, 2012 11:06 PM
slooger99
Nov 24, 2012 02:07 PM
Griffen
Aug 16, 2011 08:13 AM
