Electrical Post information/questions/Issues about Electric parts here.
07 Civic 1.8L won't start
Old Dec 16, 2021
AKMO21's Avatar
AKMO21 is an unknown quantity at this point
Unhappy 07 Civic 1.8L won't start
Hi all,
First time here, but I'm not sure where else to turn. I've been having issues with my 2007 Civic not starting. It started out as just a sort of sluggish start, but would turn over. Then it became that it would try to turn over, but wouldn't successfully start. Now, it doesn't even try to turn over. There isn't a single click when I turn the key, there is no like rapid clicking from the starter either. We got the starter replaced with a brand new one and it worked for about a week or so, and now it's back to not starting again. We have also replaced the battery with a brand new one, even though the one that was there was only a year old (harsh starts from living in Alaska, but I've since moved out of state). I replaced the batteries ground wire as well, because it wasn't looking so good. This afternoon I replaced the ignition switch as a lot of google searches had sort of led me in that direction, but still no luck. I believe the fuel pump is fine as I can hear the slight hum when the key is turned to accessory (took out the fuel pump relay to be sure that's what I was hearing and without the relay, no hum). I also don't think it's the alternator as I've had a few people test it (admittedly just places like O'Reilly, but also roadside assistance checked it for me once) and was always told it was fine, aside from that, all lights and powered items still work just fine. I have heat/AC, power windows, radio, headlights, brake lights, dash lights, everything still turns on, but the engine just won't turn over. Anyone have any idea what I should do?
Sorry for the long post, and I appreciate any thoughts, guidance and help!
Old Dec 16, 2021
Re: 07 Civic 1.8L won't start
after it starts, does it run fine?
Old Dec 16, 2021
AKMO21's Avatar
Yes, when it would start it ran really well.
Old Dec 16, 2021
FRSam's Avatar
Click Here
I'd check ground wires. Could be a corroded one that is getting worse over time.
Old Dec 16, 2021
or broken wires somewhere, pull the wiring out and check?
Old Dec 17, 2021
BrotatoChip's Avatar
Super Moderator
Was it a cheap starter?
Old Dec 17, 2021
AKMO21's Avatar
What do you consider to be a cheap starter? I believe I got an Ultima Select Starter (it was from O'Reilly Auto) and it was a little over $200. It did have this problem before we replaced the starter, and we replaced it thinking that was the problem.
Old Dec 18, 2021
Keylargo's Avatar
Keylargo is an unknown quantity at this point
Originally Posted by AKMO21
Hi all,
I had the same problem once, replaced starter, battery and had the alternator check. Alternator was good. I finally had it towed to the Honda dealership. After $150 later, it was the ignition fuse.
jimmycrackorn28
Engine start problems
Feb 12, 2020 08:25 PM
99FeatherStar
Jan 2, 2020 12:11 AM
thatboi901
Jun 15, 2011 10:48 AM
mc670
Feb 5, 2011 08:20 AM
mikekellog
Sep 15, 2007 08:49 PM
