Electrical Post information/questions/Issues about Electric parts here.
Tachometer not working, speed shows zero, ABS AirCon not working
Old Nov 16, 2019
Akashghadge's Avatar
Akashghadge is an unknown quantity at this point
So I have 8th Gen Civic, few days ago suddenly the Tacho meter stopped working, its lights also went off and so the digital information at the bottom, like temperatures and all.
the Digital speedometer shows zero, fuel meter shows empty and heat gauge shows no indication as well.
Resultantly, The Seay Belts are not working, The ABS is old and Air Con is not working either, all these lights are showing in dash.
can anyone help?
take a look here
Old Nov 16, 2019
Re: Tachometer not working, speed shows zero, ABS AirCon not working
all fuses good?
Old Nov 17, 2019
all fuses good?
yes. I checked all related fuses, they all seemed fine.
Old Nov 18, 2019
when all dash lights goes Christmas tree light up, battery is not supplying enough voltage. Electronics go crazy.
Either charge battery and see if that solves or new battery
Old Oct 28, 2021
avisingh's Avatar
avisingh is an unknown quantity at this point
can anyone help?
take a look here
Hello,
I have the same problem. Did you find a solution. Please share.
Thank You
Old Nov 1, 2021
vj94's Avatar
vj94 is an unknown quantity at this point
Unhappy Re: Tachometer not working, speed shows zero, ABS AirCon not working
Originally Posted by avisingh
Hello,
Thank You
I also face this same issue. It usually starts working when I leave the car with hood open on a hot sunny day. Revert to me if you find any permanent solution to this issue. Thanks
2011civic
Electrical
Jan 10, 2024 07:31 PM
frederickhsu
Apr 8, 2017 07:41 PM
mattee77
Jan 4, 2010 01:35 PM
kgaulton
Jul 8, 2009 11:36 PM
skatetolivelts
Mar 27, 2009 12:09 PM
