No power other than hazard lights
Old Jan 4, 2010
mattee77's Avatar
mattee77 is an unknown quantity at this point
Please help, I have nothing working other than hazard lights, everything has stopped working, the car wont turn over, all the electrics have stopped working. i think the alarm went off while i was away so thought the baterry had died, only hazards work when i connect jump leads. Any Ideas.
honda civic se executive 2001 Y reg
Old Jan 4, 2010
CraigW's Avatar
Re: No power other than hazard lights
If your battery was drained to a very low state you will have to let it charge up for a while before attempting.
If you crossed polarity on the jumper cables when attaching you may have blown 1 of the larger amperage fuses.
Old Jan 4, 2010
check the battery voltage with a multimeter to start, then buy a small charger if its low (below 12v).
steveneddy
May 19, 2015 02:39 PM
Fastfebur
Apr 22, 2015 01:37 PM
civic_gt
Apr 19, 2015 08:15 AM
SSMatey
Apr 13, 2015 06:09 PM
supercivic01
South
Nov 30, 2001 11:27 AM
