Electrical Post information/questions/Issues about Electric parts here.
Honda civic 2006 4 door right rear window not working
Old Sep 2, 2019
Azzurri29's Avatar
Azzurri29 is an unknown quantity at this point
Hi,I test it with the test light,the master switch and the rear right window switch the wire blue and red and pressed up and down the light goes ON either way.all three windows are working.i test the motor direct from the battery and it's working.Can it be the driver switch is defective.
Can someone help me out and will be very appreciated.
Thanks
Azzurri29
Old Sep 29, 2019
Re: Honda civic 2006 4 door right rear window not working
You didn't get an answer because either your port got buried or no one knows the answer. I don't know for sure, but did you test that the window works from the switch on the rear passenger door? If it does, there's a wiring issue. If not, it's probably a regulator issue. I forgot if each window has its own fuse, but that's be worth a look too
edit: have you tried removing the regulator and testing it on a working switch (e.g. plugged in to the rear driver's side (assuming it plugs in. I'm not sure if it will or not. It should) and seeing if it operates from there? If it does, you probably have a wiring issue. If it doesn't, but that rear driver's side operates its original window regulator, it's probably a regulator issue.
Old Sep 29, 2019
Azzurri29's Avatar
Hi,
The driver and right rear switch is not working but all the 3 windows switch is working.With the jumper wires strait from the battery the window goes up and down when wire reverse on the rear right window.I think the regulator is fine.i tried with the rear driver side switch and the same issue.
Thanks in advance
fire331
Mar 18, 2018 01:02 AM
over45
Mar 20, 2016 04:48 PM
botmark
Jun 2, 2014 08:57 AM
dougal813
Apr 16, 2012 10:16 PM
Dalton
Jan 9, 2012 11:49 PM
