How To Reset Power Window Controller
Old May 24, 2014
botmark's Avatar
botmark is an unknown quantity at this point
Does the 7th gen civic even have a power window controller?
I have an '02 LX 4-door.
I just replaced the driver side rear power window motor which had failed.
Now the window works as follows:
Driver side rear door closed:
Driver switch doesn't work.
Rear passenger switch only makes the window go down.
If I then open the rear door, both switches work in that they can make the window go up or down.
When I close the door again, the rear passenger switch again can only make the window go down, but not up.
Hence I think the controller is confused. Anybody know how to reset it, other than disconnecting the battery?
Thanks!
Old May 24, 2014
Re: How To Reset Power Window Controller
No reset, no control unit other than the master switch.
Sounds like....Wire broken (either brown/white or brown wire) in the rear door harness where it flexes in the door jamb. Peel back the rubber covering to find the broken wire...
Replace harness for left rear door.
Part #13
32754-S5A-000
$16 USA http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CIVIC&catcgry 2=2002&catcgry3=4DR+LX&catcgry4=KA4AT&catcgry5=WIR E+HARNESS
$31 Canadian (part #12 in their catalog) http://torontohondaparts.com/PartsList.aspx?model=CIVIC&year=2002&doors=4door&g rade=LX_%28CC%2cABS%29&cat=electrical&illid=6097
Old May 24, 2014
botmark's Avatar
Thank you very much for the helpful and informative post.
Based on your suggestions, some preliminary tests seem to verify that it is indeed a wiring issue. (Too bad I just replaced the motor, I should have been more thorough)
I'll have to do some more experimenting/testing but I'll report back what I find.
Old Jun 2, 2014
botmark's Avatar
Update:
Based on your advice I removed the wiring harness to inspect/test it. While doing so 4 of the 5 wires broke clean off. I removed the fatigued sections on all 5 wires and spliced them back together. Re-installed and the window is now working fine.
Thanks again for the help!
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
got2kids
May 9, 2015 06:45 PM
