Electrical Post information/questions/Issues about Electric parts here.
rear driver side window.
Old May 25, 2019
Kristoliquid's Avatar
Kristoliquid is an unknown quantity at this point
Hi i was trying to get my window down with the front and rear switch and it doesnt.
When i pull the switch up and put my ear against the door, I hear a click noise, but nothing happens.
What could it be? thanks )
Old May 27, 2019
GolNat's Avatar
Prelude Owner
Re: rear driver side window.
Remove door panel and check the window motor. You can run power to it and check to see if it runs.
Old May 27, 2019
How can I run power through it? Thx
Old May 27, 2019
Should invest in a variable DC output power supply to test some **** out?
Old May 27, 2019
Colin42's Avatar
Have any cordless tools? Could use the battery from that, or even a 9 volt will probably make the motor try
Old Jun 8, 2019
I've used a power tool battery to make the window go up and down. I guess the motor works.
What could be the next step.
Thx in advance!
Old Jun 8, 2019
Colin42's Avatar
Check the switch for continuity could also test the motor connector for power and ground the switch is operated
Old Jun 19, 2019
I bought a test light and tried some **** out. I got one wire in the front switch and one wire in the rear switch when I press up and down, the light turns on in both ways. Is that a clue? And no it's not the red always hot wire when it's on (II)... I kind of made sense of a legit wire diagram.
Thx.
Old Jun 21, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Broken wires in the rubber door conduit in the driver's side front or rear. Mine were broken in the driver's front and affected the passenger's rear which would open but not close.
fire331
Mar 18, 2018 01:02 AM
over45
Mar 20, 2016 04:48 PM
botmark
Jun 2, 2014 08:57 AM
Jebus Super
Jun 5, 2012 01:34 PM
KhaosKid
Apr 30, 2012 08:07 AM
