Clunk on bump [solved]
Old Jun 19, 2024
Meanie's Avatar
Meanie is an unknown quantity at this point
I have a 2014 Civic with a clunking sound on the passenger side on most bumps that's been going on for about a year now. I had it looked at by my local garage who told me it was my shock. I replaced the shocks and it still did it so I reinstalled the original shock and tested it and it's not loose. Recently, another sound started from the driver's side. Then I checked into it and discovered a very small clicking sound when I turned the shock and realized the bolt wasn't completely tightened. Thus, I tightened it and it went away. I assumed I didn't tighten enough when I reinstalled them. Therefore, realizing such a small sound made a big impact and now determined to find the passenger side noise again. I tried moving all connecting parts with my crowbar and think I hit on my rear spring. It made a sound just like when I hit bumps after I was able to move it with my crowbar. So a stupid question is, I'm assuming those springs should be seated well without play, correct? The rubber dampers seem a bit loose as well. Should they be seated without being able to move? What are the possibilities of the springs wearing out compared to the rubber mounting dampers? Should I replace everything anyway just to conclude the noise? Any other input is appreciated.
Old Jun 19, 2024
BrotatoChip's Avatar
Super Moderator
re: Clunk on bump [solved]
Have you confirmed sway bar links are okay?
Old Jun 19, 2024
Meanie's Avatar
Yes. I tried moving them with the crowbar and tried yanking them. Other than the slight pivot they normally provide, I could not get them to move any other way. Worse case, I could buy a pair for $35 just to ensure they aren't the issue.
Old Jun 20, 2024
GolNat's Avatar
Prelude Owner
You can just disconnect them and go for a drive to confirm if they are bad.
Old Jun 20, 2024
Meanie's Avatar
Didn't think of that. It won't damage anything for a brief spin?
Old Jun 21, 2024
Colin42's Avatar
Nope
Old Jun 21, 2024
Meanie's Avatar
Originally Posted by Colin42
Nope
Ill do then report back. Thanks
Old Jun 21, 2024
just tape them to bar before going
Old Jun 27, 2024
Meanie's Avatar
Thank you all for your input. I rechecked the area and decided to do my best to yank, tug, snap, etc on the links and it made a sound just like I hear when driving. Therefore, I decided on the advice to remove and test. It was a bitch to remove since the allen head bolt stripped and I couldn't get the nut off. So I decided to cut them off with high hopes it's the culprit; if not, they are cheap enough to replace. I cut both ends and now have nothing. I went for a drive and normally I would hear it as soon as I backed out of my driveway but nothing. I hit every bump I could see and still no sound. All this time, over a year, I dealt with that driving me insane and it was the problem. I'm ordering a new set. Thank you all again for the help and advice.
I found best prices online. Is it ok to drive without it for a few days?
Old Jun 27, 2024
just be careful in corners
Old Jun 27, 2024
Meanie's Avatar
Re: Clunk on bump [solved]
WIll do. Parts arrive tomorrow.
Anthony_76
Jan 1, 2013 08:30 PM
kiwi133
Apr 11, 2004 03:22 AM
Lek
Jun 19, 2003 07:34 PM
vicLX
Mar 9, 2003 01:15 AM
