EPS Motor removal. 06 civic si
Old Apr 17, 2023
Wonderbread's Avatar
Wonderbread is an unknown quantity at this point
Trying to remove the EPS motor in my 06 civic si and it will only come out a little ways. Is there something internal holding it together? I can't seem to find a YouTube video on it. Turning it into a race car and I was told it would be like a manual rack without the motor.
Old Apr 18, 2023
BrotatoChip's Avatar
Super Moderator
Re: EPS Motor removal. 06 civic si
What's the point? If it were hydraulic power steering, I could see removing the pump to reduce engine drag. But it's EPS. The electrical load isn't that much while the car is moving. Above 100 MPH it isn't actually doing anything.
If you do remove the motor, you better make sure you seal the opening into the rack. Service manual doesn't say anything special. Just remove the motor after removing the three bolts.
Old Apr 18, 2023
We've been having problems with eps failure in both cars so I wanted to know if it was an option. Felt stuck when pulling it out and didn't want to destroy anything getting frisky with it. Thanks for the response!
Old Apr 18, 2023
wouldn't that also throw codes in ECU?
Old Apr 18, 2023
Super Moderator
You did remove the steering rack first?
Bubbleman
Mar 16, 2008 12:25 AM
Mustang5.0HO
Oct 25, 2005 09:29 PM
SLO REX
Engine Swaps
19
Feb 8, 2005 01:50 PM
Grounded
May 18, 2004 09:04 PM
