I need to replace the Power Steering Feed Hose on my 2008 Civic LX. (I have traced the source of a major fluid leak to the metal part of this line - the pump just empties the reservoir out onto the ground!)
Does anyone know what size wrench I need to get the nut off the end of the line that attaches to the rack? My wrenches go up to 19mm but that size doesn't seem to fit. I tried to measure the nut with calipers, but the space is too cramped to get them in there.
For reference, it's Item 4 in this image. The nut is on the right end near the arrow labeled "B-33-10 B-33-20"
re: Power Steering Feed Hose replacement [solved]
Maybe 21,22. Since you're replacing the line, you could break the line off close to the nut and use a socket if you have enough room, the socket will grip more area than the wrench. Works great for brake lines as weĺl
Following up to close the loop... the nut is 21mm. Once I had the right size wrench. I was able to break it free. But the nut was so rusted it would not rotate freely around the pipe, so I ended up having to use a tube cutter anyway. At that point I didn't need a socket because I could turn it out by hand.
Photos attached showing the old vs. new PS hose. And a close up of the break! It was separated completely while I was wresting with the rusted nut, but obviously the leak was pretty large and the joint was weak.
