mild screeching noise when turning left or when accelerating
Old Jul 27, 2022
Surana_80's Avatar
Surana_80 is an unknown quantity at this point
My 2012 Honda has a mild screeching noise(that can be heard from inside) when turning left or when accelerating the car.
The car has recently had an oil change and has less than 50,000 miles on it (don’t recall exact miles, but can provide that if needed). Prior to the oil change, there were no issues with the car.
See below link to hear the sound when turning left: Civic sound when turning left or accelerating
Are there any suggestions on how to diagnose the issue? I am going to take to Honda (who did the oil change) but they’re like you’re going to charge me for diagnosing it. Any thoughts on what the issue is?
Old Jul 27, 2022
Re: mild screeching noise when turning left or when accelerating
power steering related.
check if they dropped oil on the powersteering belt
Old Jul 27, 2022
Surana_80's Avatar
Hi, thank you for responding.
My understanding is that 2012 Honda Civic does not need power steering fluid. I pop the hood and checked but could not find anywhere where I could pour power steering fluid. I was told that the car has an electric power steering and therefore does not need a fluid.
Are you suggesting that they probably dropped some fluid on the power steering belt? Is the belt easily visible and can be cleaned up by myself? Thanks again
Old Jul 27, 2022
oh, darn, for some reason I thought you posted on the 7th gen cars section.
Yes, you do have EPS, no belts, my bad.
Best bet is taking it back informing it started having the issue after servicing
ThomasSchroeder
Feb 2, 2018 07:42 AM
JRHAWK9
Feb 17, 2005 02:13 PM
flotsamm
Feb 21, 2003 08:33 AM
slick
Oct 7, 2002 09:56 PM
DarkCivic
Oct 7, 2002 12:14 PM
