Power steering leak [solved]
Old Feb 22, 2022
270kcivicgx's Avatar
270kcivicgx is an unknown quantity at this point
Mine leaks, I can visually see it and add a few ounces every couple months. It's getting worse, so I'm trying to figure out exactly where it's coming from. Anyone know a common place it would leak from? Is it just a seal? Or do I need to replace the power steering pump? It's getting bad enough that it leaves a small puddle in my garage after a few days. I'll try to take a picture and post it here.
2010 Honda Civic GX (Natural Gas Model)
270,000 miles
Old Feb 22, 2022
Colin42's Avatar
re: Power steering leak [solved]
Could be lines, rack, maybe pump. If you look at where the puddle is in relation to the engine bay that might help.
Post pictures, get under the car and have a look if you can.
Old Feb 22, 2022
no common known failures, not normal
clean thoroughly to find where it is coming from
Old Mar 13, 2022
tradosaurus's Avatar
tradosaurus is an unknown quantity at this point
Same thing with me. Sometimes the spring clamps will not hold tension after many years.
I would replace all spring clamps with screw type clamps.
Old Mar 20, 2022
I found it weird that there is only one small bolt that hold the one line as pictured here. Nonetheless, i replaced o rings and no more leak.
zorro2114
Suspension
Dec 19, 2021 07:46 PM
94civicd16z6
18
Jul 26, 2012 03:09 PM
sloth
Dec 24, 2011 08:21 PM
jytech
Sep 12, 2011 05:51 PM
mancao
Jul 6, 2010 10:42 AM
