Steering shakes when you turn the wheel
Old 05-15-2010
Emmad's Avatar
Emmad is an unknown quantity at this point
Unhappy Steering shakes when you turn the wheel
I was looking at a friends 2006 honda civic today because she had a belt that was making so much noise. After I sprayed it I had her start the motor to see if it had stopped. Sure enought nothing came from the belt and pullys. I did notice as I was scoping out her motor as it was running a potential problem. Under the alternator there was is bolt (accross form the fan) as the car was running the bolt was shaking. I had her turn the car off and the 4 inch bolt came right out. I also noticed that the threads were snapped. Can some one tell me what part that is under the alternater and if the 4 inch bolt holds it to the block? I am wondering if the violent shake when steering is something to do with the part not being properly connected. The power steering fluid is topped up and clean. If anyone has a parts breakdown they can send me that would be great too.
Old 05-15-2010
Re: Steering shakes when you turn the wheel
pics would help alot, i hope its not an engine mount bolt. its just hard to figure out which area. is it the bolt holding the alternator on? i had a similar situation where i developed nasty belt squeak, turned out the alternator bolt had completely backed out and was about to fall out. this causes the belt tension to loosen and eventually come apart. but that doesnt describe the wheel shake. i think thats even more serious.
conspiracy90
06-07-2023 01:01 PM
bravo79
Suspension
18
02-10-2022 09:52 PM
edgenet
05-02-2015 08:00 PM
matt95401
12-07-2001 07:31 PM
Hobby2K
Bolt-on Engine Performance
11-09-2001 04:08 PM
Quick Reply: Steering shakes when you turn the wheel
