2015 Civic EX Sedan Transmission Fluid Change
Old Nov 7, 2023
mmitsch's Avatar
mmitsch is an unknown quantity at this point
I just read that I should change the tranmsission fluid in my 2015 Civic EX Sedan every 50,000 miles. I'm a little worried -- it has about 70,000 miles on it and I want to get it done ASAP.
I have 4 quarts of the HCF-2 fluid and I believe I need 2 washers? Can somebody confirm I have the right fluid, the right amount adn what the 2 washer p/n's are?
It's a CVT transmission and I'm hoping I didn't hurt it by waiting. Is there other stuff I should change too? Any filters, etc.?
Thanks!
Mike
Old Nov 7, 2023
FRSam's Avatar
Click Here
Re: 2015 Civic EX Sedan Transmission Fluid Change
You're probably not at the damage stage, but I certainly wouldn't put it off a whole lot longer.
HCF-2 looks to be correct.
I've never replaced a crush/drain washer in my life and it's never ever leaked. It should be fine - either way, Honda dealer.
I believe those CVT's have an internal filter but the transmission needs to be dropped. Not sure that's worth the effort given that will probably last a while.
Old Nov 7, 2023
mmitsch's Avatar
Thanks for the quick response!
I’ll get to the Honda Dealer for the washers (if needed) and get the car in to our mechanic. How often should I have this done? I’ve seen done posts recommend every 30,000 miles.
Old Nov 8, 2023
BrotatoChip's Avatar
Super Moderator
Does it have maintenance minders that pop up? If so, anytime there is a 3 in the code you should replace the fluid.
mutineer
Transmission
Apr 16, 2025 06:12 PM
corysam
Transmission
Jul 22, 2023 09:02 AM
David13
Transmission
Aug 28, 2022 04:30 PM
noodles
Regular Maintenance
Jul 7, 2021 02:40 PM
green01civic
Nov 11, 2010 10:09 PM
