Clutch issue
Old Aug 1, 2023
LaciRenee's Avatar
LaciRenee is an unknown quantity at this point
Clutch issue
Car doesn't want to go into gear when I first start driving. I have to physically force it into gear. After I drive a few miles it starts getting easier but I find 1st gear on take off to be the worst. It's like it is engaging prematurely? When I have the clutch completely to the floor it is like I have it engaged? 2006 Honda Civic Si
Old Aug 1, 2023
Colin42's Avatar
Re: Clutch issue
Check fluid level, either the slave failed or the clutch did
Old Aug 1, 2023
LaciRenee's Avatar
Re: Clutch issue
Fluid is good.. adjusted the clutch once already but it only fixed it for a day and it just gradually went back to not shifting 😔
Old Aug 1, 2023
Colin42's Avatar
Re: Clutch issue
Probably a bad slave then
Old Aug 2, 2023
LaciRenee's Avatar
Re: Clutch issue
I'll try that first, thank you!
Old Aug 13, 2023
LaciRenee's Avatar
Re: Clutch issue
Ok, so I figured I would give an update. I put a new slave cylinder on it and ended up having some trouble getting it bled. I did get it pretty close as I stopped and had a mechanic use one of those suction things.. anyway, it definitely shifts better but still isn't right. One minute I have great resistance in the pedal and it shifts great. Then all of a sudden I lose all pressure, forcing me to throw it into neutral, pump the clutch til it has pressure again and then shift into gear.. I may try changing the master cylinder and then go from there 🤯
Old Aug 13, 2023
Colin42's Avatar
Re: Clutch issue
That sucks, hopefully the new master solves it
threeoten
Transmission
Dec 10, 2015 11:08 PM
14BATZ
Jan 11, 2011 02:50 PM
dagra7
Apr 8, 2010 11:04 AM
smacneill
Buy, Sell, & Trade - Archive
Oct 19, 2009 12:47 PM
Maple50175
Jun 17, 2008 10:40 PM
