Late shift at high RPMS
Old Jan 17, 2023
HondHybrid's Avatar
HondHybrid is an unknown quantity at this point
I have a 2007 honda civic hybrid automatic 120k miles.
My car went into limp in mode the other day. scanned the car: misfire cylinder 2a and 2b, p0420, and p0746.
Changed the tranny fluid(flushed) and engine oil and all filters and strainers. Engine oil was extremely low only 1 quart left, but looked fine just old. The transmission fluid looked relatively old so I went with a full flush. No metal shavings and no oil or fluid mixing with coolant.
Checked Drive pulley solenoid looked fine cleaned it, had 5.8 Ohms (within spec) and jumped battery power(it clicked nicely).
reset all the codes went for drive.
shifted nice into drive gear was driving smooth until I took it on the freeway. Shift target is high from 2-3 gear at above 4k rpm. Drives fine after that. Stall speed is Low at 2k. Didn't return to limp mode.
I haven't checked the spark plugs but I've changed them within the last 2 years ( a while but still)
haven't had a chance to check if DTCs returned.
it also has an extremely hard shift from P -R and R-N and vice versa. No rough shifts to any other selector position. which leads me to believe these hard shifts have nothing to do with the what I mentioned above and is probably gear selector but ill worry about that later rn I just want the car to drive and automatically shift normally.
Old Jan 18, 2023
Colin42's Avatar
Re: Late shift at high RPMS
Check fluid level
Old Jan 18, 2023
HondHybrid's Avatar
Originally Posted by Colin42
Check fluid level
fluid level is fine check it cold and hot.
Old Jan 18, 2023
Colin42's Avatar
As per the owners manual? On level ground, car hot but off, in park.
Old Jan 18, 2023
HondHybrid's Avatar
On the steepest hill I could find. just kidding.
yes according to the manual.
Old Jan 18, 2023
Colin42's Avatar
Sorry have to check.what fluid did you use?
Old Jan 18, 2023
HondHybrid's Avatar
0w-20 crude non refined
Old Jan 18, 2023
Colin42's Avatar
For the tranny? Supposed to cvt fluid, honda fluid preferred.
Old Jan 18, 2023
HondHybrid's Avatar
oh for the tranny yes I used cvt fluid. 5.1 L the level is fine.
a little update I checked all the solenoids today they all have continuity within spec. They also all activated just fine.
cleaned all the affiliate speed sensors. still slips intermittently, and high rpm shift target.
only the left is to check transmission pressure but I’m almost positive the clutch plates are worn.
stall speed will sometimes hit target.
throttle actuator works within spec.
MAF is also working.
fuel trims are almost maxed out. No obvious leaks that I can see at least.
plugs are going to come off keep ya updated.
no codes but I do have the misfire count PID going off every so often.
civic2013
General
Feb 12, 2022 07:50 PM
ldannecker17
Transmission
Sep 10, 2021 08:12 PM
Strikereleven
Oct 3, 2014 05:22 PM
nojro
Jul 20, 2013 10:38 AM
2k1SINCE00
Jun 9, 2002 01:40 AM
