Transmission, other issues, or both?
Old Aug 14, 2022
hkwalker1's Avatar
hkwalker1 is an unknown quantity at this point
I have a 2011 Honda Civic, but I’m not really a huge car guy although I’ve been learning as I fix the car myself over the years. Bunch of problems happened at once: misfiring to the point of not running, poor engine performance, and not shifting properly. I fixed the misfiring by replacing spark plugs/coils, but now I’m left with a car that can’t shift up properly without the car rocking back and forth as it struggles. The engine power is half of what it was a few months ago.
Check engine light codes:
- P2647: Rocker Arm Oil Pressure Switch (A) Circuit High Voltage/VTEC System Stuck on
- 61-1: ABS Control Unit Low Voltage
I’m wondering if the transmission is giving out (the car has 224,000 miles), or if transmission related symptoms can be explained by the other problems I’m having. I don’t want to put money into a doomed car. Thanks!
Old Aug 14, 2022
Re: Transmission, other issues, or both?
check if you have any engine oil left
Old Aug 14, 2022
hkwalker1's Avatar
Yep, just changed it too. It was my first thought. Transmission fluid is fresh too.
Old Aug 14, 2022
https://www.engine-codes.com/p2647_honda.html
Old Aug 22, 2022
hkwalker1's Avatar
UPDATE: another oil pressure related code, and another one related to voltage. new code came up after:
changing vtec selenoid & cleaning corroded battery terminal. any thoughts on the connection between all of these codes?
p0523: Engine oil pressure high-voltage
p2647: Rocker arm actuator controller stuck bank one
61-1: ABS control unit low voltage
Old Sep 2, 2022
hkwalker1's Avatar
Changed engine oil pressure sensor and VTEC selenoid assembly. No improvement. The problem seems to be getting worse.
Matt Carroll
19
Oct 27, 2020 08:27 PM
Zax90
Aug 6, 2018 10:54 AM
james0013
Nov 16, 2015 12:56 PM
nojro
Jul 20, 2013 10:38 AM
DTTheEmperor
Jan 11, 2009 01:07 AM
