2014 cvt rubber plug
Old Apr 17, 2020
carl8's Avatar
carl8 is an unknown quantity at this point
Have a 2014 Honda Civic with 83k miles. I had the cvt fluid changed at the dealer 3 times, most recent at 78k. I popped the hood one day and noticed the filler plug was not where it was supposed to be and resting on top of the case. Is there any chance fluid escaped or should I not worry about it?
Old Apr 17, 2020
Colin42's Avatar
Re: 2014 cvt rubber plug
Easy enough to check the fluid level, you need to clean the vent cap to stop that from happening.
Old Apr 18, 2020
^This.
The transmission case vent is a short metal tube with a rubber cap kindaa L shaped, If it gets clogged, pressure change inside the trans can make the rubber plug pop out,
Adnowo
Transmission
32
Feb 24, 2023 10:46 PM
Bruce.Ringler
May 13, 2018 04:05 PM
msidd
Mar 14, 2018 10:45 AM
Shad Welch
Transmission
Feb 13, 2018 07:19 PM
odie
Apr 3, 2004 02:12 PM
