8th Gen 2006 - 2011.
2015 Honda Civic Coupe CVT Level
Old May 13, 2018
Bruce.Ringler's Avatar
Bruce.Ringler is an unknown quantity at this point
Hello,
I have a 2015 Honda Civic Coupe, with Continuously Variable Transmission LX.
I check under the hood weekly, this weekend I noticed the transmission CVT plug was off on the engine and some fluid have spilled out. I cleaned the plug good and put it back in.
I have CVT fluid but how do you check the CVT fluid level in the trans? I just don't want to guess and pour any amount in. The Owner's Manual has nothing and Google video has nothing.
Thanks, Bruce
Old May 13, 2018
Re: 2015 Honda Civic Coupe CVT Level
How many miles on it?
My dealer still recommends 30,000 fluid service intervals, so if yours is anywhere close to that I'd say to just have the trans fluid serviced (drain and fill) and that will take care of the fluid level.
If still under warranty see if the dealership will replace the rubber plug and check/add fluid if necessary
Fluid level is critical, too much can be just as bad as too little
Remove and clean out the trans vent tube cap (directly below thermostat housing), as that little thing clogging with dirt can cause the rubber plug to pop out
You know that trans MUST use the HCF-2 fluid from Honda, yes?
Fluid level check, see the reply in this link: http://www.9thgencivic.com/forum/gen...ml#post1862474
Old May 13, 2018
Thanks, Yes I have Honda CVT fluid, however, is there anyway to check the level?
Bruce
Old May 13, 2018
You didn't bother to click the link I provided in the previous post?
Old May 13, 2018
Thank you, got it.
Bruce
rponfick
Sep 18, 2016 08:22 AM
echoid83
Jan 22, 2016 09:10 PM
youandme
Apr 15, 2015 12:42 AM
ridethelighting
Nov 10, 2011 12:09 PM
