Auto trans filter on 2012 civic
Old Jan 16, 2020
DYNAMICAL's Avatar
DYNAMICAL is an unknown quantity at this point
Does anyone ever change these? I know its not really a maintenance item but why not?
Old Jan 16, 2020
Colin42's Avatar
Re: Auto trans filter on 2012 civic
It's inside the case.... Be a bit of a job to do it.
Old Jan 17, 2020
mac25's Avatar
Dr Krieger of Modification
They're "lifetime" filters.
Just dont leave your fluid in the transmission until it's a rotten black mess, and you'll be fine.
plus always use honda fluid.
Old Jan 17, 2020
DYNAMICAL's Avatar
Inside the trans case? If thats what you mean then no, its somewhere below the airbox.
Just like the lifetime fuel filter that they put in the tank now? Sheesh.
Only use hondas fluid? You mean strictly honda dw1? If thats the case then my car is screwed dude. I bought mine with 24k on it and it now has 83k. I'v done 4 trans fluid drain+fills with castrol import. When will it blow up?
Maybe it will be lucky like my 02 which I owned from 110k until trading it in at 199k? All I used for that car was castrol as well. Trans was fine. I still have the maintenance records on that as well if you'd like me to tell you how many times I didnt use dw1.
Old Jan 22, 2020
mac25's Avatar
Hopefully your fine 😁, before I swapped to manual I used Total G3 atf in my 2002, worked fine.
But really you shouldn't mess around with atf, because there are many variables which could result in issues.
-metals used in transmission
-viscosity profile across heat range
-seal compatibility
-oil film requirements
-detergent ability to remove deposits
-warranty approval
ATF is not as simple as MTF
mtf you only really look at viscosity and GL4 or GL5 requirements.
Old Feb 9, 2021
DYNAMICAL's Avatar
Its been a long time since I logged in figured I would update. I changed the filter some months ago. Its not a bad job if youre patient. I have seen some requests in other posts wondering what the inside of these filters look like. So I hacked this one I took off.
Old Feb 9, 2021
Colin42's Avatar
That doesn't look factory
Old Feb 9, 2021
I thought the same, but then again I haven't dicked around with 9thgen engines. Looks like it is. #5 on the diagram is the AT filter. P/N 25430-PLR-003 for you folks looking at this in the future
Old Feb 9, 2021
Colin42's Avatar
Well I'll be damned
Old Feb 9, 2021
Well I'll be damned
literally what I said when I found the diagram
Old Feb 9, 2021
DYNAMICAL's Avatar
Yeah its factory. I should of took a pic before hacking it. I thought of it after the fact.
The replacement looked exactly the same although not from honda. Got one from rock auto. Ill put a new one in every other fluid change or whatever. IDK yet.
Old Jul 7, 2021
BanoOmg's Avatar
BanoOmg is just really niceBanoOmg is just really niceBanoOmg is just really niceBanoOmg is just really niceBanoOmg is just really nice
Oh wow, I also assumed there was just an in-case filter! What's the maintenance interval on it?
Old Jul 7, 2021
scroll up a few posts
Old Jul 7, 2021
BanoOmg's Avatar
Yeah, I saw that, but that post was also made before the grand reveal of the filter existing outside of the transmission case.
I looked elsewhere and found that it is a lifetime filter. I was excited to learn something new.
Old Jan 14, 2022
patm95's Avatar
patm95 is an unknown quantity at this point
I've replaced mine before. It's not too bad of a job. I know they say lifetime filter, but it's easy enough and they are only like 30 bucks for oem.
Old Dec 4, 2022
DYNAMICAL's Avatar
There is no maintenance interval according to Honda so I guess we call it "lifetime" But then again there are vehicles out there who the manufacturer claims trans fluid is "lifetime" I think its more like they only expect the trans to last a certain number of miles. Point is use your own mechanical intuition and do what you want.
On my car its an easy job. I wanna see how many miles I can get out of the car so IMO it will help change the filter vs not changing the "lifetime"
HD$
Jan 6, 2017 07:52 PM
senicalj4579
Feb 6, 2013 04:22 PM
trixman
Nov 9, 2011 09:33 AM
stratos285
Dec 8, 2004 11:00 AM
blckpwdr
Aug 1, 2003 12:18 AM
