2012 transmission fluid question
Old Jan 8, 2019
jHudson's Avatar
jHudson is an unknown quantity at this point
Took my 2012 LX to Jiffy Lube for an oil change. Was told i needed a transmission flush. I was told they put in ATF Synthetic trans fluid , but in the O.M. it says specified fluid type is ATF DW-1 Is the formerly mentioned fluid acceptable or do i run the risk of damages if i dont put ATF DW1 in?
Last edited by sdaidoji; Jan 12, 2019 at 05:52 PM. Reason: changed to a descriptive subject "as per forums rules" - people don't read... any point in asking if they don't read?
Old Jan 8, 2019
Re: Quick question
It's funny. Places like that can't afford to use the right fluid, and people like me can't afford to use the wrong fluid.
You already know it's not the fluid that Honda specifies.
Is it absolutely compatible? Nobody knows for sure.
Do you notice anything unusual with the trans now?
If there's any question, it's probably best and safest to flush out the wrong and install the correct Honda fluid ASAP.
Can you DIY this? Buy a case of Honda DW1 fluid and go to work
Old Jan 10, 2019
Mikeyyy's Avatar
Mikeyyy is an unknown quantity at this point
Re: Quick question
Di they tell you and get your permission to do the flush or did they just go ahead and do it??
Old Jan 11, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Quick question
You need to either return to the lubeshop and find out what they used, or replace the fluid with dw-1.
atf fully synthetic is just the job code, not the brand used.
for example in most cars at my shop we use Total G3. Total is the brand G3 is the product; which has a data sheet stating which oem fluids are covered.
I've been at my shop for 7 years and there has never been an issue with G3.
that being said we do use oem dw-1 for auto hondas, and not G3, as G3 only covers dw-1 outside of warranty.
Old Jan 11, 2019
Re: Quick question
Originally Posted by mac25
and there has never been an issue with {brand-X logo.jpg}..........
that being said we do use oem dw-1 for auto hondas, and not {brand-X logo.jpg}
Hey mods, Can we put something like this on a flashing arrow sign?
Old Jan 12, 2019
rogerscivic's Avatar
rogerscivic is an unknown quantity at this point
Re: Quick question
iffy lube should of used the corect fluid to start with. if they did not carry it, they should of never put in anything they were not sure it would work.?
Old Jan 12, 2019
Colin42's Avatar
Re: Quick question
It's Jiffy lube they don't care they just want your money
Old Jan 8, 2020
chuffsy's Avatar
chuffsy is an unknown quantity at this point
Re: Quick question
No feedback from first poster ?
Geez
Old Jan 9, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: 2012 transmission fluid question
Embarassed ?
El Polloso
21
Mar 25, 2018 03:54 PM
Kennykenny
Jul 25, 2016 07:12 AM
Chuck K
Mar 16, 2016 08:26 PM
Doug Lassiter
23
Feb 23, 2015 06:16 PM
jm11
Jul 19, 2014 11:52 AM
