AT fluid?
Old Feb 14, 2015
Doug Lassiter's Avatar
Doug Lassiter is an unknown quantity at this point
AT fluid?
Time to change ATF in my 2003 LX. I see strong statements that I should use only OEM Honda ATF Z-1. But I don't know where to get it (no, I'm not going to get ATF on e-Bay!) In fact, it isn't really obvious that it is still sold, and what we're seeing now is DW-1.
So the question is, what should I use, and what stores carry it? It would be a shame to have to order it online, as shipping charges are often more than the cost of the fluid itself.
Old Feb 14, 2015
Re: AT fluid?
Z-1 is now obsolete.
Hondas DW-1 is the newest correct fluid for your trans.
Available at almost every Honda and Acura dealership.
HTH
Old Feb 14, 2015
Re: AT fluid?
OK, that makes sense.
Now, I understand that DW-1 is synthetic, but Z-1 is not. I probably have the latter in there now. Can I assume that I can just do a drain-and-refill rather than a flush? Do they mix well?
Actually, I believe Honda doesn't even recommend a pressure flush, but perhaps just a 3x refill.
Old Feb 14, 2015
Re: AT fluid?
Yes they mix just fine, and all we do at my dealer is drain and fill once for a routine service.
Correct. No chemicals or machines.
Nobody gets a flush (3-4x D/F) here at my dealer unless they really want it or they have contaminated fluid.
Old Feb 14, 2015
CraigW's Avatar
Re: AT fluid?
Z1 went fast.
Local Honda dealer close by ??
Order online where they will ship it. Got 2 gallons of Honda blue usps.
Old Feb 14, 2015
Re: AT fluid?
Sounds straightforward. Yeah, if I was going to wait 60K, or if the fluid was nasty, I'd probably want to clean it out entirely, but one drain and fill every 30K should work fine. And yes, I guess it would be pretty stupid to make a replacement fluid that you couldn't mix with the original!
What should I look for, re contaminated fluid, in Z-1? If I was getting cross contamination from the radiator, what would it look like? I guess I could check for this at the dipstick.
Old Feb 14, 2015
Re: AT fluid?
We recommend drain and fill every 30k.
I personally like to change more often than that.
I was changing ATF on my mothers 02 Accord at every other oil change, and I changed my own 12 Civic ATF at 10k.
A guy I work with has a 98ish Accord 4 cyl., he changes ATF every time the car goes in the air.
You would think...
All you can do is check the color and smell of the fluid unless you wish to send fluid samples to a lab for evaluation. (Color is not really a good indication of condition, though we judge by that all the time anyway.)
Contamination isn't a usual problem.
Pink milkshake on the dipstick.
Or red oil pumped into the radiator and overflow bottle, and hoses would get soft and spongy if it's had oil in the cooling system long enough.
Old Feb 14, 2015
Re: AT fluid?
Excellent. I need to run to the dealer to get some quarts (and probably a new gasket), and I'll be good to go. Wow, every other oil change??
I gather the "milkshake" contamination indicator means it looks cloudy, instead of clear? On the dipstick, mine seems to be light brown and transparent. I guess that means it's just old.
Old Feb 14, 2015
Re: AT fluid?
Yours should hold a little under 3 quarts per each drain and fill.
Yep. Those Accords had a variety of.... *ahem*... "spectacular" trans issues. Changing fluid early and often is about all we can do, and even that can't prevent problems.
It would be looking like a pink milkshake. Literally.
Ever seen an engine that got a bunch of antifreeze mixed in the oil? That looks like a chocolate milkshake.
ATF and coolant mixed looks like strawberry milkshake.
Most likely.
Old Feb 15, 2015
Re: AT fluid?
Thanks very much for the excellent advice. As long as we're on the topic though, what's your feeling about Valvoline Maxlife versus DW-1? A bit cheaper, and closer for me.
Old Feb 15, 2015
Re: AT fluid?
Does Honda recommend it?
I work for a dealership, we use the correct specified fluid in our shop.
More:
DW-1 is full synthetic, Maxlife is a blend.
Here, have a look at this thread from a couple years ago:
https://www.civicforums.com/forums/1...51k-miles.html
Does that make it any more correct?
I know damn well others here have different opinions about the Valvoline though. See that thread I linked above or do some searching here.
Old Feb 15, 2015
Re: AT fluid?
Make SURE you have figured out how to fill the trans, and verified it does actually work to fill the trans before you drain the trans!
The basic long funnel usually isn't long enough!
Old Feb 15, 2015
Re: AT fluid?
Fair point about making sure I can fill it. I have a (clean!) large funnel with a (clean!) 3-foot piece of hose firmly attached to it. That hose should sit loosely in the dipstick hole. I haven't actually done it yet, but I don't see why it shouldn't work.
I'm glad that the fill is with the dipstick hole rather than behind a fill plug.
Points noted about DW-1 versus Maxlife. Now, I don't expect Honda to recommend anything more than what it sells, but still ... . DW-1 is just a buck or two more per quart (and, FWIW, my dealer is about half a mile further than my auto supply store). Why take chances on a few bucks?
Old Feb 15, 2015
Re: AT fluid?
At least yours won't belch fluid all over if you fill too fast.
Other cars sure will LOL
Something else to check: See how loosely your dipstick fits in the hole. The rubber seal shrinks over time, allowing fluid to ooze out....
The new is a different design. (I forget when the change was made)
(H/T to Matt_75 for the pic)
The handle style is the clue to the original or updated part.
Fresh dipstick is about $12US or $8 on the internet
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CIVIC&catcgry 2=2002&catcgry3=4DR+LX&catcgry4=KA4AT&catcgry5=AT+ ATF+PIPE+-+SPEEDOMETER+GEAR
You can ALWAYS find cheaper, that includes just about anything.
I see DW-1 for 8.30 per quart (MSRP). You only need 3 for a simple drain and fill.
A half mile difference? Seriously?
Are you walking this trip? Are both your legs broken or something?
Old Feb 15, 2015
CraigW's Avatar
Re: AT fluid?
DW1
Certainly check your dipstick for 01-05.
Have considered getting a replacement for my 2010s... a bit loose at 5 years.
Old Feb 15, 2015
Re: AT fluid?
That's an interesting point about the seal on the dipstick shrinking with time. I noticed that my dipstick is really not well seated in the hole, but just sort of fits loosely on top of it. I was surprised that the fit wasn't more secure. I didn't look at it closely, but that would make perfect sense that the rubber seal had shrunk. Looks from the handle that I have the original. Yes, I should get a new one. I guess the reason why there is a rubber seal is because that hole is also the fill hole, unlike the oil dipstick, which is not in the fill hole.
Now, the half mile was a joke, sort of. The dealer is close, but the auto supply stores are closer. The distance to either is really a non-issue.
Old Feb 15, 2015
Re: AT fluid?
I have a "funnel" adapted (built) to insert in the skinny dipstick tube. On some of the transmissions that have a fill plug (mostly on V6's), it's easier to just stuff this into the dipstick tube to refill. May not be any faster, but easier.
I can be really lazy.
Sometimes it takes a lot of work to be lazy.
The dealer I'm in moved only a couple miles toward the edge of town (closer to an interstate) several years before I started working here. They lost business because of that, some people say it's too far to drive now..... Yeah, right.
Old Feb 16, 2015
Re: AT fluid?
Well, I think the point is that in my 03 Civic LX, there isn't a "skinny dipstick tube" for ATF, but rather just a half-inch hole, facing upwards. That's easy to drop a hose into. But yes, you'd think an up-facing hole would be easy to pour stuff into, except it's well buried under a lot of other stuff. So you really need a lengthy hose.
Old Feb 16, 2015
mikey1's Avatar
Re: AT fluid?
i have a long funnel that will reach, but i guess if somebody doesn't, you could always just remove the air intake, its not like its hard or takes alot of time
Old Feb 21, 2015
Re: AT fluid?
OK, job done, in half an hour. Advice here was right on. Thanks again.
The only joke was that my Honda dealership was selling the 18mm washer for $3.30! The guy at the counter admitted that was pretty strange because the 14mm was listed for $0.33. So Honda loses decimal points, a have to believe.
Old Feb 21, 2015
Re: AT fluid?
The only joke was that my Honda dealership was selling the 18mm washer for $3.30! The guy at the counter admitted that was pretty strange because the.....
.....MSRP is $2.42
http://www.hondaautomotiveparts.com/...ISSION+HOUSING
Old Feb 21, 2015
Re: AT fluid?
Well, looking on line for 14mm crush washers, they are indeed also a few bucks. Not sure what he was looking at when he quoted 33 cents.
Actually, a few bucks for an aluminum washer is kinda obscene. Maybe if they were gold plated? Of course, if you buy a bucket of them the cost goes way down.
Old Feb 22, 2015
mikey1's Avatar
Re: AT fluid?
you can re-use washers like that.....many times,
they are not like nylon ones that you need to replace every time
Old Feb 23, 2015
Re: AT fluid?
Yes, that was pretty evident after I took the old one out. They are "crush" washers that, even with 40 ft/lb, don't really get crushed. Lesson learned.
sf3r8z
Apr 19, 2016 01:53 PM
Raiool
Oct 1, 2015 10:42 AM
ken4444
Sep 30, 2015 07:37 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
speedlever
Sep 24, 2015 07:18 PM
