Output seal
Output seal
I got a 2010 hybrid civic and the axel seal is leaking I’ve put a new one in and installed flush put the seal seems lose and not tight. Any help will be appreciated it’s my daughters car and she travels for school
i should add it does have a new axel on it as well and I can find no play in the half shaft
Re: Output seal
The OE seals aren't like some other types of seals that require much beating to install, these may push right in with only a little resistance. The original seal probably was easily removed as well? .
Aftermarket seal? Try one from a Honda dealer
Re: Output seal
How so? Loose fit in the transmission?
i can push the seal in with my hand. I’ve ordered one from Honda. Should I put some silicone around the outside of the seal.
dnmacdon
Aug 30, 2016 10:05 PM
Skillzzz
Jun 26, 2015 09:46 PM
