Higher RPM noise after low trans fluid
Old 02-11-2018
lgn98868's Avatar
lgn98868 is an unknown quantity at this point
Ive got a 2012 lx with around 60k miles. I changed the oil and put new brakes on it about a month ago. While doing this I checked the trans fluid and it was low, so I topped it back to appropriate level.
It seemed like after this the car was slightly louder above the 40 mph range, and sounded like it was running around 1000 rpm higher than it really was. Engine rpm was pretty much consistent with what it’s been since I’ve had it.
A couple of weeks ago I felt the trans slip a little more and checked fluid—-low again and smelt burnt. Topped it back off and have been checking it frequently and have not been losing any.
Since this second time it’s gotten low, the noise seems like it’s gotten a little louder. Running at 70 mph it sounds like the engine/trans would be going 90-100.
Any advice on what to do? I know the losing trans fluid needs to be addressed, and oddly it was consistent until the second loss. This time i hit a big puddle at low Speed and the bottom of the car really got washed, enough that one of the plastic covers on the bottom for folded over on itself. I got under and bent it back and the next time I drove it that’s when the second low fluid issue happened.
Have been refilling it with Honda atf dw1 as specd by the owners manual. Thanks for any help/advice.
Old 02-11-2018
Wankenstein's Avatar
Re: Higher RPM noise after low trans fluid
Get the leak fixed and do a 3x3 ATF drain and fill.
Old 02-11-2018
lgn98868's Avatar
not at all doubting you, but why do you think that would remedy the noise? I understand the physics of the fluid could be altered since I didn’t completely drop it all and refill, but I feel like there is some physical damage to some extent and not sure where/what to do about it.
Thanks for your response
Old 02-11-2018
lgn98868's Avatar
Here’s a link to what it sounds like....was only going like 68 and maybe 2200 rpm here
Old 02-11-2018
Originally Posted by lgn98868
Here’s a link to what it sounds like....was only going like 68 and maybe 2200 rpm here.
I can't discern the noise. Bring it to a Honda dealer or transmission shop.
Old 02-12-2018
Sounds like an airplane is flying next to you? Wheel bearing bad.
Swerve side to side (within your lane) a noisy wheel bearing will usually get a bit quieter as you swerve to one side.
Old 02-12-2018
lgn98868's Avatar
nope, tried that. Thanks though.
Old 02-12-2018
Dr Krieger of Modification
mac25's Avatar
Just to make sure, you are using the correct fluid right?
Old 02-12-2018
lgn98868's Avatar
As far as I know, but correct me if I’m wrong.
Some more info—took it out of gear and out in neutral today while it was making the noise, still had the same sound. Have done pretty hard weaving and sound doesn’t change so highly doubt it’s wheel bearing.
One more thing, when it gets above 70 mph, and only >70, it starts a bit of a metal scratching type sound that almost seems like it is coming from behind the front left wheel/directly in front of the steering wheel.
Old 02-12-2018
DW1 is the current correct fluid
Pretty much eliminates everything engine related, exhaust related, and eliminates most the the transmission.
That pretty much leaves the tires/bearings/intermediate shaft bearing/differential in the front end as your possible front end culprits.....I'd include axles but they won't sound like an airplane flying next to you
(is that what it sounds like? My laptop is not great with sound reproduction).
Still can't rule out a wheel bearing....May need to raise the wheels off the ground to do more checks (let them spin at speed while listening to the hubs with a stethoscope, or letting one tire spin while the other is held still)
Rotate the tires front to rear, see if noise moves? Look for choppy tread on the edges, usually inboard edges.
IDK. Splash shields dragging the ground or a tire? Rotor backing plates got bent? Brake noise?
Old 02-12-2018
lgn98868's Avatar
Going to jack up and check bearing in about an hour and will look under and see what I can see.
Old 02-12-2018
lgn98868's Avatar
Got the front off the ground and checked both wheels for play , found none. Then put in neutral and turned both wheels by hand. The wheel I suspected had a surprising amount of resistance to it, but when I did the opposite side, they were fairly even. When I say surprising, I mean it had a lot more than I was expecting it to normally have (ie more like a trailer spindle).
Didnt see anything underneath that would be making noise. Trans fluid has been consistent since the last time it got low.
What does the putting it neutral and still getting the sound not rule out in regards to the transmission?
In regards to the sound, I wouldn’t necessarily say an airplane next to me, just sounds like the car is turning 4500 rpms when it’s only doing 1800-2500.
Old 02-12-2018
I'd have it safely supported with both front wheels off the ground (shop lift) helper sitting inside it to run it in gear, force the trans to upshift and run about 40-50 MPH or whatever speed the noise is loud and obvious.....then use a stethoscope to probe for wherever the noise is loudest
Or cut that speed in half, then stop one wheel at a time to make the opposite wheel spin (it will spin at double what the speedometer says because the differential doubles the speed), listen again for the loud one
Brake drag....Stuck caliper? Stuck pins? Jammed up pad or shim?
the countershaft and differential.
Old 02-12-2018
lgn98868's Avatar
I’m gone away to school right now and only have the little emergency jack with the spare to worth with. Don’t want to try running it only supported by that jack.
I did put some new pads on it when all this started, and it did have some different sound to it, but since the sound has gotten louder I don’t really feel like it’s due to the pads. Also don’t think that would explain the scratchy sound heard around 70 mph.
I guess im ultimately thinking there is some kind of damage done to the transmission in the period it was driven low enough in fluid to burn it—maybe 20-30 miles. We have a gmc truck we feed cattle on the farm with and the fluid got low in it and started making a similar scratchy sound when accelerating and ultimately the trans went out of it a few weeks later.
Old 02-13-2018
Hey, did you know that Hondas automatic transmissions are to be checked with the engine OFF?
Honda is probably the only company on the planet that has you check auto trans fluid this way. If you try to check fluid level and add with the engine running it may end up wrong.
Old 02-13-2018
lgn98868's Avatar
I had been checking and adding with the engine off. Fluid was burnt and low so it had definitely gotten hot at some point.
Contingency
02-01-2013 06:27 PM
bobbytee98
11-27-2010 11:05 PM
CivicClasseatal
03-10-2010 07:24 PM
ryan509
06-08-2009 06:23 AM
HotDamnItsDavid
08-10-2004 01:01 AM
Quick Reply: Higher RPM noise after low trans fluid
