06 Belt tensioner bolt Repair Question
Old Jan 30, 2025
Sundragon's Avatar
Sundragon is an unknown quantity at this point
NEW EDIT
Honda offers a specific tool kit from Time Cert for repair of the tensioner bolt>
I hope this will help others, took a while researching this to find the solution to this problem.
SEE ATTACHED :::
Why doesn't Honda recommend using a Time Sert to restore the threads for the belt tension-er bolt?
The bulletin states if the threads are not repairable to replace the short block assembly!
The repair bulletin states clearly to NOT use a Time Sert to repair the threads on the tensioner bolt. See attached diagram.
EDIT: After doing more in depth research I found a Honda Service News Article promoting the use of Time Serts! LOL I guess they can't make up their mind.
see attached:
Any replies welcomed.
thanks
Sundragon
fivealive
Jun 5, 2023 06:52 AM
Asekunola
Feb 22, 2021 08:10 AM
Kevin_646
Feb 4, 2012 11:21 PM
bob1942
Jan 17, 2012 02:27 PM
yamahamaxim700
Dec 29, 2011 09:35 PM
