Tensioner is moving-Timing belt
Old Feb 4, 2012
Kevin_646's Avatar
Kevin_646 is an unknown quantity at this point
Civic Experts,
I'm replacing the timing belt on my 2003 Civic LX. I have the new belt on. Instructions say to manually turn the engine over twice. I'm doing this and watching the belt.
Here's what happens: The tensioner moves, the spring stretches a lot. I assume it's the compression stroke, where there is more pressure on the belt, it seems the tensioner, the spring doesn't keep the belt tight.
Question: Is this what is supposed to happen? Is the spring the only thing keeping the tensioner tight?
Or could I have missed something, while putting the tensioner back on? There's only one bolt, in the center, holding the tensioner on, right? and a spring, supposedly pulling on the tensioner, to keep it tight?
Is that right, or do you think I'm missing something?
Note: I didn't understand the reference to "grenade pin" or "allen wrench," so I didn't use those. I did get it taken apart and put back together.
Thank you,
Kevin
Old Feb 4, 2012
Re: Tensioner is moving-Timing belt
You are spinning the crank the wrong direction. Crank turns counterclockwise.
Old Feb 4, 2012
Kevin_646's Avatar
OK, thank you for that information. Now I've really messed it up. I've stripped the threads. I've stripped the threads where the bolt goes in, in the engine block. This is the bolt holding the tensioner in. The manual says to tighten it to 36 ft/lbs, but that's too much and stripped it.
Anyone have any ideas on how to fix this, make this bolt work? There are some threads left, it will tighten some.
thank you,
Kevin
Old Feb 4, 2012
Hard to say.
I never loosen or remove the tensioner to change the timing belt unless I am replacing it. I remove the spring and let the pulley roll, replace the belt, reinstall spring.
Other people have said a replacement tensioner bolt is longer, but I can't confirm that.
Heli-Coil? Time-sert?
Did you cross-thread it and booger a few threads? Maybe something like this would straighten the threads up http://www.nes.co.il/158905/Nes-21-5-16-7-16-8-11-mm
Old Feb 4, 2012
Check out the videos from that website, looks like it could be handy. First video is that tool.
http://www.nes.co.il/158905/Videos
Old Feb 4, 2012
BlueEM2's Avatar
Whachya lookin at?
At this point.. Try that tool. If it does not work take it somewhere and get it profesionally fixed. The last thing you want to do is to make it worse than it already is. Tensioner is not something to toy with. Good luck getting the tool in there BTW.
WaryDriver
Aug 16, 2015 11:22 AM
Ray Darvi
Aug 12, 2015 11:55 AM
loosescrew84
16
Aug 11, 2015 07:08 PM
WaryDriver
Aug 8, 2015 05:08 PM
1khilari
Jul 9, 2015 08:12 PM
