08 Civic Coupe auto stuck in limp mode
Old Aug 18, 2023
Blueberryeyeboy's Avatar
Blueberryeyeboy is an unknown quantity at this point
just replaced the transmission from an issue that started about two months ago. i havent driven it since then due to it being apart from us replacing the trans. i though replacing it would fix the issue. i put everything back together and even put in new cv axles, motor mounts, filters, fluids, coolant, starter, and still i am in a kind of limp home mode where i cannot go above 4000 rpm. im not entirely sure where to start diagnosing here and any help would be appreciated.
Old Aug 18, 2023
BrotatoChip's Avatar
Super Moderator
Re: 08 Civic Coupe auto stuck in limp mode
4k rpm limiter has nothing to do with the transmission. Pull fault codes.
Old Aug 18, 2023
no codes. just "BCM Fault" and thats from the TPMS sensors for tire pressure
Old Aug 18, 2023
Super Moderator
Are you in park? Google says the rev limit is 4k when in park. If the limit is 4k when driving, there really should be a fault code.
Old Aug 18, 2023
nah in park it goes to redline but in drive it won’t go past 4k
Old Aug 18, 2023
Colin42's Avatar
Checked engine oil level? Did you replace any sensors?
Old Aug 18, 2023
oil level good. no sensors needed replacing so i just left em alone
alanM100
General
Jun 22, 2021 01:51 PM
shatheone
Transmission
Aug 23, 2019 07:42 PM
higogo
Jul 8, 2018 09:44 PM
Lou2010
Aug 17, 2010 11:15 AM
xe2k2
Aug 11, 2002 01:29 AM
