help me start an auto car
Old Aug 10, 2002
xe2k2's Avatar
xe2k2 is an unknown quantity at this point
my bro's car is having a problem with a starter motor. I know how to start a manual car with starter motor problem, but since he's car is an auto i have no idea. Is there a trick to start a car with auto trans car? any tips? thanks ....
Old Aug 11, 2002
JesuSouLjaH's Avatar
JesuSouLjaH is an unknown quantity at this point
starter motor? do you perhaps mean just starting his car in general? if you can't turn the key, maybe you're not in the parking (P) gear. also, sometimes you might have your wheel turned in place where it locks. try budging the wheel a lil in either direction. if i'm totally off and a starter motor is something else, then my bad for this waste of post space haha. just trying to help yo.
Old Aug 11, 2002
civic510's Avatar
civic510 is an unknown quantity at this point
I think the only solution is to replace the starter motor.
Old Aug 11, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
check the starter you might need to replace it...or get a dealer to check it
Old Aug 11, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Maybe if you would describe what is happening when the car is not starting. It's kind of hard to diagnose stuff over the internet from just "Car dosen't start".
Is there a grinding noise when it tries to start?
Does the engine turn over but dosen't fire up?
Is there just a clicking sound, but the engine dosen't turn over?
Is there no sound at all when you turn the key?
What is the voltage reading on the battery? (Use a volt meter, the scale on in dash volt meters typically suck)
