Intermittent starting problems on 2015 civic
Old Nov 25, 2022
run4life's Avatar
run4life is an unknown quantity at this point
Problem started suddenly a few weeks ago when I went to leave and it wouldn’t start. Accessories would turn on but it will not crank. Eventually it fired up. I replaced the battery, and this seemed to solve the problem, but a few days later it happened again. I realized that by turning the key very slowly I can pretty reliably get it to start, but when I attempt to start it normally it usually will not. Any idea what this could be?
Old Nov 25, 2022
Colin42's Avatar
Re: Intermittent starting problems on 2015 civic
Ignition switch might be on the way out
Old Jul 25, 2023
emich's Avatar
emich is an unknown quantity at this point
Same problem here. 2013 LX 150k mi. When turning the key a single click and starter not engaging. Battery and terminals, starter relay, neutral safety switch are OK. Turning the key second or third time or shifting the gear N to D and back to N helps.
Old Jul 25, 2023
remove, clean and reinstall grounds and battery terminals
Old Aug 8, 2023
emich's Avatar
Sounds like a Starter issue. Most common problem is the contact plate inside the starter, smaller than a penny is worn out.
To my surprise Duralast starter from Autozone has much larger contacts. For sure they'll last longer.
AutobahnSHO
Jun 21, 2022 10:11 AM
kristine.thomas
Electrical
Sep 6, 2021 09:56 AM
Sandoval
Electrical
May 13, 2021 04:22 PM
rednek
Nov 3, 2010 11:38 AM
samssung100
Jul 24, 2009 04:42 PM
