Starter Issues
Old May 26, 2022
jennkemp09's Avatar
jennkemp09 is an unknown quantity at this point
Starter Issues
Hi, can the starter be tested if the car still turns on? My car turns on but after I drive it a while, turn the car off, turn it back on etc. when I crank it on I hear a scratching sound and I have trouble starting it. But after a few tries it does start. I've had this problem before, experienced the exact same thing, same sounds, etc. and eventually died on me and had to get the starter replaced. I have a 2012 Honda Civic Coupe.
Old May 26, 2022
Colin42's Avatar
Re: Starter Issues
Starter could be on the way out, some parts stores can test starters. Or you can test it yourself with jumper cables and a screwdriver
Old May 27, 2022
Wankenstein's Avatar
Re: Starter Issues
Check for loose and/or dirty connections to starter both positive and ground.
Carry a long piece of wooden dowel, 1/2" pvc, or other object, plus a hammer to use to bang on the starter next time this issue happens. It's a band-aid until the starter is replaced. Banging on the starter can help it start. Shown in attached link below:
https://m.youtube.com/watch?v=J9mfzqVp_nc
fabled523
Dec 20, 2016 07:57 PM
pomona
Nov 2, 2016 08:23 AM
gabrown2
Apr 11, 2015 08:22 PM
2003civlxhockey
Florida
Jan 22, 2014 07:20 PM
Deu
May 11, 2002 04:34 PM
