2012 Honda Civic Coupe - Damaged Oil Pan
Old Dec 18, 2021
jennkemp09's Avatar
jennkemp09 is an unknown quantity at this point
I took my car for a regular oil change a couple of days ago because I'll be driving out of town tomorrow. They told me that I'll need to replace the oil pan because it's damaged and drain plug stripped. My car does not currently leak any oil and I have no driving issues. Does anyone have a similar experience with this issue on a 2012 Honda Civic? And how much time I really have to get this replaced? I won't be able to get this replaced for another 2 - 3 weeks.
Old Dec 18, 2021
Re: 2012 Honda Civic Coupe
Anyone who had hit something in that same spot
Old Dec 18, 2021
jennkemp09's Avatar
Can you explain what you mean?
Old Dec 18, 2021
Colin42's Avatar
Re: 2012 Honda Civic Coupe - Damaged Oil Pan
Dealer or independent shop told you this?
if it's not currently leaking (get under the car and look) I'd leave it until you need an oil change again and then replace the pan at that point. If an aftermarket pan is available it should be significantly cheaper than an oe pan.
I had to do this on my '00 coupe
Old Dec 18, 2021
jennkemp09's Avatar
Hi,
It was an independent shop that told me this. And thanks for your reply. I'm leaning more towards your suggestion.
Old Dec 18, 2021
Colin42's Avatar
Get a quote from them, and from a couple other shops
Old Dec 24, 2021
tradosaurus's Avatar
tradosaurus is an unknown quantity at this point
How do you know the shop didn't damage the threads on the oil pan?
Old Dec 25, 2021
quartermilecame's Avatar
quartermilecame is an unknown quantity at this point
the shop did damage the oil pan threads. That looks like overtightening. Why replace the pan? Rethread it with helicoil or larger pan bolt. Squirt grease in behind threads and start the fix. I definetly woiuldnt replace the pan for that.
Old Dec 25, 2021
Simply installing longer bolt with gasket will also fix it. Depends on what type of repair you want. Personally I do not let other people work on my cars because of this type of work damage.
Old Dec 25, 2021
There are also tap kits that willl oversize the hole and allow a larger drain pan bolt to be installed. I do wonder what replacing the pan and labor would cost.
amodedude1
Aug 25, 2019 03:39 PM
IntrinsicFactor
Mar 28, 2019 02:40 PM
WICKEDPHOTO
North East
Mar 11, 2012 11:59 PM
AdamGregg
Feb 8, 2012 09:41 PM
lastcall1901
North Cali
Apr 19, 2011 04:07 PM
