2012 Civic - Cracks developing in oil pan
Old Jan 2, 2019
IntrinsicFactor's Avatar
IntrinsicFactor is an unknown quantity at this point
Angry 2012 Civic - Cracks developing in oil pan
I have a 2012 Civic with only 24K. The aluminium cast oil pan is now developing 4 to 5 inch long cracks but not yet leaking......problem not due to over tightening of oil pan screw or oil pan being hit/struck from below.
Old Jan 2, 2019
Colin42's Avatar
Re: 2012 Civic - Cracks developing in oil pan
got pictures?
Old Jan 2, 2019
GolNat's Avatar
Prelude Owner
Pics?
Old Jan 3, 2019
Casting marks. Not cracks.
Old Jan 3, 2019
Old Jan 3, 2019
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Take a metal file. File off the lines that bother you. A casting line will go away with minimal effort. A crack with still be visible after filing them down. Either way those look much more like casting lines. I see lines like that on cast aluminum all the time. I even have friends that work at a factory that makes oil pans for Honda engines. I wouldn't worry about it unless it actually becomes a leak.
Old Jan 3, 2019
Thanks very much for the info. The Honda dealership simply wants to change out the pan for $574 CDN. They never mentioned anything about filing. Less profit in filing I guess ? Again, thanks for all your help.
Old Jan 4, 2019
mac25's Avatar
Dr Krieger of Modification
It depends on if they are indeed cracks, or if they are casting lines.
If they are cracks, replace the pan, but shop around for pricing.
They may be casting lines though as the others have mentioned. This is caused when a small crack appears in the casting material (usually "green sand" or similar). So though it looks like a crack into the pan, it is actually a thin metal protrusion, out of the pan surface.
Old Mar 28, 2019
SC Tiger's Avatar
SC Tiger is an unknown quantity at this point
Those look like casting marks or "casting splatter". At my work we use Honda small engines (power equipment) and they often has those.
Often happens when the die is wearing out. To be safe you could just file a section of it and see if it is into the pan.
Old Mar 28, 2019
SC Tiger's Avatar
Honestly I wouldn't be surprised if they don't 100% know what those are either. I only know because I used to work with a guy who spent decades in that industry.
I'd monitor it for leakage just to be safe.
vwaudi34
Dec 29, 2012 01:18 PM
ariasm1
Buy, Sell, & Trade - Archive
Feb 22, 2009 07:40 AM
knight_321
Jul 16, 2007 09:58 AM
khmaitiger
Oct 4, 2003 01:54 AM
CIVICMAN67
Engine Swaps
May 18, 2003 02:31 PM
