Oil Pan Removal
Old May 13, 2003
CIVICMAN67's Avatar
CIVICMAN67 is an unknown quantity at this point
Oil Pan Removal
has anybody removed their oli pan to run the oil return? Or dose anybody know a different way?
Old May 13, 2003
CIVICMAN67's Avatar
sorry, OIL pan
Old May 13, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
the only different way that I can think of is a getting a custom oil pan w/ the return line already drilled. They come with temperature sender hole drilled too. You could order one from Moroso, but I have no idea how much they would charge you.
Old May 14, 2003
CIVICMAN67's Avatar
I have no problem with using mine, I just can't get it off the car! We 've tried just about everything, I am going to call the dealership today!
Old May 14, 2003
Boosted2k2's Avatar
Don't you just remove all the bolts around it? Maybe they put sealant in between the pan and the gasket.
Old May 14, 2003
REDVIC's Avatar
One of few in the 13's
REDVIC is an unknown quantity at this point
Yeah... just take off all the bolts surrounding the oil pan... and get a screwdriver or something to pry the oil pan off... The OEM sealant is pretty strong soo but some muscle into it....
Old May 15, 2003
CIVICMAN67's Avatar
Removed it last night! I was using a screw driver w/ no luck. Last night I brought home a pry bar from the shop and it came off in a second. I don't have a pry bar at the house so thing I tryed was door panel remover and a screwdriver. So I be running by tonight.
Old May 15, 2003
MadWheel's Avatar
Premium Boosted Member
sweet lol now i know how to do mine
Old May 16, 2003
mike0404's Avatar
mike0404 is an unknown quantity at this point
hey, can you post a diy for this one..
Old May 17, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
it is easy. All you do is remove the nuts & bolts around the pan, and pry on the lip. It will come off in a sec. It took us less than 30 mins to remove the pan and weld in my return line and install the pan again.
Old May 18, 2003
MadWheel's Avatar
catalyst...what location on the pan did you choose for the oil return line? I just want a spot that will be the easiest to run the hose. thanks
Old May 18, 2003
Catalyst's Avatar
put it as far to the top as you can, and about an inch to the side of the tranny brace. You may have to angle it towards your turbo, and angle the one on your turbo towards it, but it will work fine.
Old May 18, 2003
Boosted2k2's Avatar
Since we are on the topic (sorta), where did you tap the oil line for the turbo?
Old May 18, 2003
Catalyst's Avatar
at the oil pressure sender. you have to use a T fitting and run it from there.
for the people who dont know where that is, it is just above the oil filter.
Old May 18, 2003
Boosted2k2's Avatar
cool. thanks
Vaguexo
Jun 13, 2015 04:11 AM
jmdcivic
May 20, 2015 09:52 PM
BootyDo
May 7, 2015 04:46 PM
leon1
Apr 28, 2015 07:32 PM
Grey
16
Jan 27, 2002 11:34 PM
