Engine Performance Modifications Post your questions about how to modify your engine here Swaps, Flashing, bolt-ons, etc.
Add ons
Old May 2, 2023
hondciv's Avatar
hondciv is an unknown quantity at this point
Add ons
Hi there, Can you add on a manual transmission to a Ex 9th gen cylinder block with change to flywheel on a automatic original Engine and transmission set up? If so is it possible to add on a Si transmission as well? To a Ex 9th gen automatic transmission set up on original block without drivetrain issues?
Old May 2, 2023
Re: Add ons
easier to buy a manual car instead of swapping a transmission.
It's called swap, not add-ons...
Old May 3, 2023
Colin42's Avatar
Re: Add ons
Sell your car and buy a manual one
Old May 3, 2023
BrotatoChip's Avatar
Super Moderator
Re: Add ons
No, an Si K series transmission won't mount to your R series engine. There would be an R series manual transmission that would work. If I remember correctly, there are minor changes to the water outlet/thermostat housing for manual transmission. Removing the water lines for the auto transmission cooler.
EGCCS22
Jun 9, 2021 12:36 PM
wheatroot
General 1st - 5th Gen
15
May 17, 2021 06:17 PM
Koda1820
General 8th & 9th Gen
Jan 19, 2020 10:39 PM
Soldierboy87
Oct 29, 2014 12:40 PM
Mikeds122
Dec 24, 2002 07:54 PM
