non-VTEC to VTEC Head swap place your information/questions on swapping the engine head from non-VTEC to VTEC
DIY - DX/LX head swap to EX Vtec
Old Apr 10, 2005
  #121
Logan3024's Avatar
Originally Posted by Nokturnl
umm, yeah. The head (esp. if milled) Will have a higher compression. With out vtec running you will have a better cam profile anyways to boot. The EX cam is hotter than the LX/dx ...not by much but every little bit helps!
Do not do this swap and NOT wire in a VAFC. Unless Vtec is engaged your only gonna have 1 intake valve open, Vtec is what allows BOTH valves to open.
I did my swap and had to wait a week for my VAFC and let me tell you above 5000 rpm to car did NOT have any power, again due to only 1 intake valve open. So boosting and not having VTEC makes no sence what so ever, it would probley cause harm to the engine if anything.
Old Apr 11, 2005
  #122
dannn's Avatar
unique conformist
dannn will become famous soon enough
can you elaborate
Old Apr 11, 2005
  #123
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
Originally Posted by dannn
can you elaborate
basically i had the same secenario at one point.. i was driving my car around too without the vafc control and it the same way it used to without the vtec... it weird cause when you go from dx/lx to ex vtec then go back again then you really notice a difference... if you want to elaborate more than go to this link
http://www.7thgencivic.com/forums/sh...d.php?t=188161
cause they explain more about how vtec works on SOHC engines
Old Apr 11, 2005
  #124
joshb_'s Avatar
Boosted 04
joshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nice
i read threw a few pages on this and couldnt find it...sorry if it was already anwsered....can you just a use a vafc instead of a vafc2
Old Apr 12, 2005
  #125
go here
http://www.7thgencivic.com/forums/sh...d.php?t=155261
Old Apr 12, 2005
  #126
joshb_'s Avatar
Boosted 04
thanks
Old Apr 12, 2005
  #127
dannn's Avatar
unique conformist
i heard you cant use the vafc
somone said only the vafc 2 works for the swap
Old Apr 12, 2005
  #128
joshb_'s Avatar
Boosted 04
really? damnit ill just get the vafc 2 to be sure then
Old Apr 13, 2005
  #129
who said that?...if you really want to get technical then "apexi" also said that the vafc2 doesnt work in our cars..... did we show them wrong.. but i think me and a few others have done the swap but we all have used the vafc2 and never tried using the vafc... as for using the vafc i know a few members on here that actually have used a vafc on there cars... thats the purpose of buying the diodes from radio shack to make it run properly.... but if you really want to save money then get the vafc and buy the diodes from radio shack.. there like a dollar and some change or something like that... but if you want to be safe then get the the vafc2... plus the vafc2 is already compatible and can also be used on your turbo setup and if you decide to do a motor swap down the road you can also use it for that to
Old Apr 13, 2005
  #130
anyways to stay on topic about the head swap.. my car is still running fine.. i even have video of it running last week at the races
http://www.xproductionz.com/mycar/mycivic.wmv
Old Mar 15, 2011
  #131
Taz$'s Avatar
Taz$ is an unknown quantity at this point
Re: DIY - DX/LX head swap to EX Vtec
Hi am tryin to make a swap anybody got good idea on Wat to use for my honda ex 02
Old Mar 15, 2011
  #132
MindBomber's Avatar
Live for the Twisties
A head swap?
The parts are all listed on the first page.
Old Apr 17, 2011
  #133
abbate2121's Avatar
abbate2121 is an unknown quantity at this point
i am thinking really hard about doing this swap, im new to the honda realm, but can you use the same block?? how much gain is achieved? with a motor with 180000miles+ would there be any issues with that?
Old Apr 17, 2011
  #134
dude...
you already have the head with vtec...
Old Apr 17, 2011
  #135
Originally Posted by abbate2121
but can you use the same block???
That's the whole idea of doing a head swap, non?
You tell us. depending on how the engine is, you might better off dropping a used engine with less miles.
create a new thread explaining that you have read this thread, BTW. this thread is supposed to be for reference to others
Old Dec 5, 2011
  #136
Duffman1977's Avatar
Duffman1977 is an unknown quantity at this point
I know this is an old post but just wondering if anyone else has done it or if there is anything extra I should do. I am looking for a head now and I already have a guy lined up that will clean it up for me and do a good valve and spring job. Just looking for any pointer. Anyone know how much you can shave the head and deck the block and still be safe. Ive done jobs like this before but on the gm 2.2. We had a 96 head on a 2000 block. It had 245 lbs of compression but only made about 6 races.
Old Dec 5, 2011
  #137
pwnsauce's Avatar
pwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the rough
id replace all the gaskets and cam seal, timing belt and water pump if your close to needing it anyways.
as for power you could do a cam upgrade to stage 1, stage 2 if you have kpro or aem ems and upgraded valve springs. if you REALLY want u could add high compression pistons and valves but i dont think that would yield enough power to justify all that work.
Old Dec 5, 2011
  #138
you do not want to mill the head past the service limit, esp not to raise compression. you will blow the gasket in no time. 128psi is the stock compression rating, and any knowledgeable machine shop should know the service limit for milling if the head even needs it. i can try and search for it in the service book, but its not much at all. i think one milling is pretty much it before you have to junk the head.
Old Dec 6, 2011
  #139
Im not looking for super high compression and I know its not going to give it that much more power. The problem we had with the gm 2.2 is the rods keep breaking. I havent had a D17 apart but I know some of the older honda motors came with extra meat you could cut down. We fixed one guys d16 and he ended with 170lbs compression. Its been 2 years later and still running strong. Im not spending the money on new rods and pistons, like pwnsauce said not enough power to justify the cost but I do have a new set of bearings ready to throw in while I have the head off. I just did the timming belt and water pump 10k ago but Im the type of person that if I have something apart then I replace what I can while im there.
Old Dec 13, 2011
  #140
droptop1988's Avatar
droptop1988 is an unknown quantity at this point
im getting ready to do the swap but im swapping in the whole motor needed a transmission got a ex package deal i couldn't pass up i am planing on doing it with the vafc2 i am just a little curious what the sensor under the vtec plug is and does it have to be used or just left open thanks
Old Dec 13, 2011
  #141
its an oil pressure sensor and is required for vtec to work.
Old Dec 25, 2011
  #142
WARNING! this is not for the faint of the heart, have not been finished yet and not worthy if you do not have the rocker arms, cams, vtec solenoid laying around, but very interesting project that another forum member is trying to do.
http://www.7thgenhonda.com/forum/showthread.php?t=25485
he is trying to convert a LX head in a EX head! only for the mechanical savvy guys, not for the runts that need to ask how-to. if you feels like asking, then it's not fer yah! you will be disqualified right there.
[attach][/attach]
Old Aug 24, 2013
  #143
yazanm's Avatar
yazanm is an unknown quantity at this point
how you will connect the vtec wiring??
i changed my motor with a vtec one.. but i dont know where to connect the EGR and the vtec valve??
can we connect them externally ??
xproductionz
Engine DIY
146
Oct 4, 2019 08:30 PM
Gunner
7th Gen Do It Yourself Articles
21
Feb 23, 2016 11:56 AM
xproductionz
60
Jan 31, 2013 05:23 AM
gearbox
Apr 1, 2012 03:16 AM
