non-VTEC to VTEC Head swap place your information/questions on swapping the engine head from non-VTEC to VTEC
DIY - DX/LX head swap to EX Vtec
Old Aug 28, 2004
  #31
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
hey... would people stop PM'ing me asking how i converted to VTEC.. read the DIY first... haha.. lol...
Old Aug 28, 2004
  #32
Havok2k1's Avatar
Wicked Pissah Admin
Stickied in Tech......
Old Aug 29, 2004
  #33
thanks havok2k1.. hopefully i will have more DIY worth getting stickied
Old Aug 31, 2004
  #34
zachgeyer's Avatar
you crazy
Old Aug 31, 2004
  #35
haha.. how does that make me crazy.. lol
Old Sep 9, 2004
  #36
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
Vegas!! I'll be in Vegas in two weeks and again in October. Now only If I can get a hold of a EX vtec head... I'll have a hook up in Vegas to do it for me. Buy some Carne Asada BBQ and some Beer about $500 total....I can swing that. J/K
Old Sep 9, 2004
  #37
well being in cali u should be able to find a head easy.. lol... if not let me know when u come down and mi mght be able to call around again for another one
Old Sep 14, 2004
  #38
zachgeyer's Avatar
void your warrtey for what
Old Sep 14, 2004
  #39
for what???? well.. if you have a warranty still then i dont know.. cause technically it is a genuine honda part... and if you have honda do the swap for you then wouldnt it still be under warranty cause it was honda serviced?
Old Sep 14, 2004
  #40
BTW... a DX/LX with a an EX head benefits all other models when boosted... a DX/LX boosted has an advantage over EX cause the DX/LX has lower compression... the EX boosted benefits over the DX/LX cause it has the vtec lobes open up to let more air in.. so take the low compression of the DX/LX models and combine that with the EX vtec lobes for more air and u got a winning combination...
as for me i will be getting a turbo in the next 2 weeks so i can post some results in a within the next month
Old Sep 15, 2004
  #41
cbaer543's Avatar
cbaer543 is an unknown quantity at this point
so I've read all of the messages and people keep on adding stuff so can someone tell me all the parts I need to do the swap? I really want to do this swap that would be great. This has just become the next thing on my list to do so I want to start collecting all the parts I need so just let me know please. Thanks
Old Sep 16, 2004
  #42
if you want to do it the cheap and easy way all u need is:
vafc2
Complete EX head with vtec solenoid
EX head gasket
thats all u need to do that.. and the DIY explains the whole thing and very simple setup to get going
but if you want to do it the other harder way you will need
EX ECU and wire harness
EX complete head
EX head gasket
now this way is similar in the setup in my DIY but i found out that after everything is installed u have to tow car down to the dealer and have them reflash the ecu and ur key so u can start the car... another side note is that the DX/LX does not have the wiring for the vtec in the harness which connects to the ecu hence which is why u need the EX wire harness.... this is also harder cause u gotta have someone wire the harness into ur car..
Old Sep 20, 2004
  #43
ramcosca's Avatar
Words on a User Title
I think I'm asking this because I'm so tired I can't think for myself but... what does this do to the DX?
Old Sep 20, 2004
  #44
haha .. ur kidding right .. anyways it allows the dx/lx to have vtec.. u should try reading the last 2 posts i did cause everything is explained there
Old Sep 23, 2004
  #45
civicstreetrcr's Avatar
civicstreetrcr is an unknown quantity at this point
Hey I did a complete swap harness and everything. I heard that you can take a shift light an set up the light voltage to trigger the vtec solenoid. is this true?
Old Sep 23, 2004
  #46
1 more thing how much voltage is needed to trigger the Vtec? 12v?
Old Sep 23, 2004
  #47
define complete swap... meaning ecu and everything or the same thing i did..??? as far as the solenoid not sure on the voltage... im guessing its 12v but its probably best to ask someone that knows for sure on go on honda-tech.com ... but like my friend told me when we did the install .. its best to use a vafc2 cause that way u can add more fuel when vtec kicks in or else ur gonna be running lean
Old Sep 23, 2004
  #48
imma go ask a friend about the vtec voltage and let u know in a bit
Old Sep 24, 2004
  #49
someguy's Avatar
someguy is an unknown quantity at this point
hey x, is it true that the ex tranny is better than the dx/lx. cause i was talking to a local speed shop about doing this head swap myself. and they said something about the ex's tranny has shorter gears, i guess so when you shift you stay in vtec. dont know, just seeing if anyone else knew why they said that. btw...good kill list. have you ever raced '00+ celica gts? j/w. later.
Old Sep 24, 2004
  #50
the ideal setup if you go turbo is
ex head
dx/lx bottom end
if you go n/a then
ex head
ex bottom end
now as for tranny goes it all is up to you...
based on what i know(but i could be wrong so dont quote me on this) is that the ex and dx/lx has the same 1st, 2nd and 3rd gears.. just the 4th 5th and final gear ratio would be different....
im gonna be boosted in about a week so i would rather have the longer gears but idealy if you go n/a then u want shorter gears.. just depends on what you wanna do and how u drive and what your main focus is for
Old Sep 24, 2004
  #51
jturbolx's Avatar
jturbolx is a jewel in the roughjturbolx is a jewel in the roughjturbolx is a jewel in the rough
Talking doing same thine but
hey thanks you have help alot so far going a step further due to cai and ny flooding on my way to lucas oil nationals in penn besides that though, i got an ex motor asemb for 500.00 bucks, cool. installing it in my shop me and a buddy of mine great, couple thins what did you do about the egr valve on the head was everythign the same when you took it off? they gave me the complete wireing harniss too not cut wow i was shocked can't use it cause don't have an ex computer oh well. got everything i need just need to know that and if you are haveing anyother problems i should know about thasnks!!
Jason
Old Sep 24, 2004
  #52
jturbolx's Avatar
one more thing
i sAw you had better coils where can get them? who sells them i have 8 of the reg. ones now lol
Old Sep 25, 2004
  #53
everything is pretty much bolt on and play... just gotta wire the vtec solenoid and ur set.. just make sure u have just a tad bit more oil in there cause the extra oil will be running into ur ex head to the solenoid.. as far as wiring goes u dont need the ex wire harness unless u have and are planning on doing and getting a few things
1.u need ecu especially if u dont want to use the vafc2 to control vtec
2.the dx/lx isnt wired with the vtec so u basically gotta pull the old wiring out and put in thte new one if u wanna use the ecu.. and yada yada.. i pretty much tried explaining this in the past few posts...
but other than that the car is running great... pulled the head and solenoid to check it and its running fine... one thing u might want to do after the head swap if u use a vafc2 is to get it tuned.... when vtec kicks in the ecu doesnt add more fuel like the Ex ecu does.. but one thing good about using the vafc2 is u can control it to turn on the same time all the time.... and its either on or off and none of this 3 stage thing other people are talking about
Old Sep 25, 2004
  #54
jkob2k1's Avatar
jkob2k1 is an unknown quantity at this point
Crazzzzzzzzzzzzzzzzzzzzyyyyyyyyyy man but worth it.
Old Sep 25, 2004
  #55
yup yup
Old Sep 26, 2004
  #56
cbaer543's Avatar
I know I have asked this awhile ago but when you say ex complete head do you mean ex head, camshaft, valve springs, retainers,cam, gasket? or is that too much stuff? I asked that awhile ago but I still wasn't sure because you said complete ex head.
thanks
Old Sep 26, 2004
  #57
complete head...cause in the ex head everything internal is different from the dx/lx stuff.. i mean if you want to u can try but u should be able to get the complete head for fairly cheap... if u shop around u can even get the whole ex engine for as cheap as $500.. unless u plan to upgrade the head parts.. u know springs retainers cam and stuff... then u dont need the stock ones... just make sure if you order upgrades that its for the EX cause u got the ex head now..
Old Sep 26, 2004
  #58
jturbolx's Avatar
500.oo
yeah i got the total engine for 500.00 i can get a few more for around this price msg for info i'll give you the number and the guy to talk to he said he had a few left. they are in ct waterbury area so shipping may cost some loot but hey if you want to take a road trip its good. lol i have the ex egr if any one needs it taking b/o for it i will be dynoing mine as soon as the fly wheel and clutch gets here so we can put the motor in and can get more pics also
Old Sep 26, 2004
  #59
i paid 500.00 for mine here locally
but the *******s wanted 450.00 for the ex tranny
Old Sep 27, 2004
  #60
WTF... just remember if u going go n/a then u want the shorter ex tranny.
but if u go turbo then better to stay with the dx/lx longer tranny
