Engine bay cleaning...some Q's
Old Oct 13, 2005
  #31
technick03's Avatar
technick03 is an unknown quantity at this point
sorry. . . . but if you are going to pressure wash/spray under the hood, you should ALWAYS leave the engine RUNNING, and keep it running for a few minutes after. If you are going to short out anything in your car by putting water on anything under the hood, you better look for a new car. Engines get wet every time you drive in the rain or snow. If you don't believe me, pop the hood next time and see for yourself. njerry is correct, and yes after market parts require special care.
Old Oct 14, 2005
  #32
pon55's Avatar
Well i have worked in electronics for many years and in autoshops for over 40-You will kill and alternator and related electronics if it gets water in it while energized!
Cars a designed to keep rain away from the electronic parts!
Do what you want, i give up!
Old Feb 7, 2006
  #33
P.O.S.B.A.S.04's Avatar
Ever Wonder What P.O.S.B.A.S. Is An Acronym For
P.O.S.B.A.S.04 will become famous soon enoughP.O.S.B.A.S.04 will become famous soon enough
god knows i need to clean my engine bay and i have come to the conclusion that the BEST way to do this would be as follows (car turned off):
1) pop hood and use leaf blower to remove any loose standing dirt or debris
2) spray on cd2 or engine cleaner of your choice
3) cover intake, dist. cap, battery and any electircal mods that are not stock!
4) use garden hose to spray down where degreaser was applied
5) when done spraying down, use leaf blower to remove standing water and a quick air dry.
6) go back with shop towels and hand clean everything that was covered before the intial spraying while drying any visible standing water.
7) after car is relatively dry around electrical areas (fuse box, dist. cap, battery, etc...) start the bad boy up and drive it around for a bit to make some heat in there, that way any water around seals & crevices will evaporate
8) Take a picture
any objections, questions, comments or concerns?
hope this helps someone!
Old Feb 7, 2006
  #34
pon55's Avatar
6) go back with shop towels and hand clean everything that was covered before the intial spraying.
8) Take a picture
You got the right idea,but unless your engine is covered in grease and oil don't use an engine cleaner!A biodegradeable cleaner like simplegreen is much less damageing to your car.
Totally dry with leafblower and polish with towles!
Remember to be carefull of stuff getting on the paint (fenders,ect).
(If you spray some tire shine on the engine after your done and dry it will make the next time a simple hose off operation!)
Old Feb 7, 2006
  #35
good call on the cleaner used...if there is grease and oil: use cd2, etc.... and simple green (and like products) for just a general clean for dirt!!
with our minds collaborating...we can do it and do it well!!
Old Feb 12, 2006
  #36
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
you definitely should not run the engine while cleaning it.. nor should you ever clean the engine when it is hot.
Old Feb 13, 2006
  #37
phuviano's Avatar
Slowest 7thgen in the GTA
Yes you should wash your engine bay with the engine off.
I've learned from real life experience. Not just facts or opinions. This is a real story. I'll tell you exactly what happened.
My friend's dad decided one day he should was his engine bay. So my friends dad starts the engine and my friend says to his dad "what are you doing".
dad: "what do you mean"
friend: "why are you running the engine"
dad: "cause you should or you'll mess up something in the engine bay"
friend: "your going to short out something if you keep the engine running"
dad: "no it won't happen:
friend: "ok, we'll see"
The next day, my friend's dad had to buy some sort of electrical component for his jeep. I don't exactly remember what part it was, but it cost $200 to replace it. It wasn't the altenator or anything like that.
Anyways, if my friend's dad wasn't so ignorant, he would have saved $200. I mean $200 is not bad, but you could have spent $200 on better things.
Old Feb 13, 2006
  #38
jerseydetailer's Avatar
jerseydetailer has a little shameless behaviour in the past
didnt want to post of pic of my car being that its stock and all but here goes
i do it monthly...
1)dont do it with a hot engine...you can crack the block
2)dont need a pressure washer...actually dont use one
3)use different brushes...
4)use a citrus based degreaser as previously stated
5)cover the intake with plasic film or a plastic bag and a rubber band, use aluminum foil on the alternator
6)when your done. do not start the engine..blow the water away wit compresses air, the blower side of your vacuum if your lucky enought to have one, a leaf blower, or if not use a rag & wring and repeat untily dry
7)spray dressing on a foam applicator, then apply to rubber hoses and such
8)if your scared bout messing up your car then you can use a two bucket method..fill one bucket with soap and water, another with just water. get different sponges and rags..use the soapy solution ,wipe down, dump in clean water, wring out repeat..it takes longer, but no water spray to worry bout..i do this in the winter when its to cold to do it outside
the end
Old Feb 13, 2006
  #39
pon55's Avatar
i do it monthly...
the end
Old Feb 13, 2006
  #40
DDragon7's Avatar
Nice, but why does your header heat shield have an opening?
Old Feb 13, 2006
  #41
that is hole is there because it is a non-vtec engine. i am pretty sure that it would be a DX or an HX that is like that. that is just where the first O2 sensor goes b/c the cat is built-in up high on the exhaust manifold.
Old Feb 14, 2006
  #42
its an 03 lx
Old Feb 14, 2006
  #43
DDragon7's Avatar
I C.
Old Feb 14, 2006
  #44
ajhdragon's Avatar
7thgens official a$$hole
its an 03 lx
still the same manifold as a dx and i think the hx, but the hx is vtec
Old Feb 15, 2006
  #45
negativecamber's Avatar
negativecamber is an unknown quantity at this point
good stuff!
Old Feb 15, 2006
  #46
where can i get mothers back to black stuff
Old Feb 25, 2006
  #47
Temp's Avatar
Temp is an unknown quantity at this point
I got mine at VatoZone
To add to the write-up by jerseydetailer, I do mine the same way except I spray down everything in sight with no-touch tire care and walk away. I don't bother hand wiping the plastic and rubber.
The end result is the same, though. Looks good.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
superstanko
Apr 28, 2015 04:38 AM
SoNiCcIvIc
Mar 11, 2002 03:37 PM
supercivic01
South
Nov 30, 2001 11:27 AM
antidote11
Nov 27, 2001 10:46 PM
