Best answer to the swirl problem????
Old Sep 23, 2004
pauldilsaver's Avatar
pauldilsaver is an unknown quantity at this point
What is the easiest, non expensive way to get rid of the damn swirls that form all over the car?????
Old Sep 23, 2004
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
try meguires gold class paste wax. its a clear coat thing!!
Old Sep 24, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
He said get rid of them, not hide them. You are going to need to use a polish / swirl remover to get rid of them. I like Poorboy's line of swirl removers myself. There are tons of polishes out there that will do the trick. Also, find your source for the scratches and stop doing what causes them. Most likely it is the car wash you are using or prodcust you are using to wash and dry your car with.
Old Sep 24, 2004
I'll give it a try...thanks for the advice
Old Sep 25, 2004
KiRiMa's Avatar
KiRiMa is an unknown quantity at this point
Make sure the wash and dry towels you use are soft.Chamois are good for
windows,but since they don't have knap ,they will press any leftover debris
against your clear coat.(The clear coat they use these days is applied in
very thin layers and is easily scratched.) Hopefully this will help prevent any
future swirl marks and whatnot.
Old Sep 25, 2004
rckdrmr's Avatar
rckdrmr is on a distinguished road
using a plush wash mitt and a waffle weave to wash and dry your car, will help minimize scratches/swirls in the future.
Old Sep 27, 2004
RedDragon333's Avatar
learning how to wash and wax a car will help prevent getting more. Never wash, apply, remove any susbstance from the car in a circle motion.
Old Sep 29, 2004
Zoto724's Avatar
l33t h4x0r
Zoto724 is an unknown quantity at this point
This has a very detailed guide on how to remove swirl marks, just go to how to's -> how to remove swirl marks. Then check out the paint protection page, i use klasse and i love it, keeps swirls from comming back(with proper care).
http://store.yahoo.com/autopia/index.html
Old Sep 30, 2004
mmisko's Avatar
mmisko is an unknown quantity at this point
Meguires 7 and 9 work very well. If you want to really do a good job then you should a good detailing job on the outside. Here's a good DIY: http://www.ephatch.com/forum/showthread.php?t=38655
I just did my car and wow... it did wonders. It's not very hard, just takes 4-6 hours to do a good job. (http://www.7thgencivic.com/forums/sh...d.php?t=176053)
Old Oct 2, 2004
jonw440's Avatar
jonw440 is an unknown quantity at this point
Agreed, washing and drying is the way MOST swirls return. Here ia a great article on washing and drying the CORRECT way. Enjoy
Jon
How to wash and dry
As for removing the swirls. It can be done by hand but a PC is the easiest and best way to remove the swirls.
PC with Sonus Pads from Autopia
I would recommend 1Z Or Menzerna polishes to REMOVE the swirls.
Here is a couple of pictures on removing swirls I did on a black Grand Prix GT.
ID:	39268   Click image for larger version
ID:	39269   Click image for larger version
ID:	39270   Click image for larger version
ID:	39271   Click image for larger version
Name:	sonus pads2.JPG
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Tim1959
Jun 3, 2015 08:15 PM
shindrome
Exterior
May 5, 2015 02:50 PM
jakeconnor
May 5, 2015 07:30 AM
CiViCPrAnInG2k1
Detailing
Nov 9, 2001 08:34 AM
