SOHC D17Ax non-VTEC - VTEC Engine Swaps Post information/questions about non-VTEC VTEC D-series engines here.
Non Vtec to Vtec swap
Old Feb 20, 2019
Rodgers18's Avatar
Rodgers18 is an unknown quantity at this point
I have a 04 civic with a 1.7 non Vtec bought a jdm 1.7 Vtec to replace due to lower end knock I’ve read some stuff that says not to bad of a swap was wanting some info on what exactly is needed seen you can run a aftermarket controller to run the Vtec instead of buying a new harness and ecu any info would be much appreciated
Old Feb 21, 2019
Slumpertcivic's Avatar
Re: Non Vtec to Vtec swap
Personally I would ignore the vtec part until after everything is done and running.
Generally your better off swapping the entire intake between them as well as your timing belt/water pump. You should also strongly consider doing a head gasket replacement.
Replacing front/rear/oil pump seals makes a lot of sense at this point as well.
As I was saying, the little extra high rpm boost bonus of vtec is the last thing you need to worry about deciding how your going to do it, getting everything else working first.
Old Feb 21, 2019
Rodgers18's Avatar
​​​​​​thank you that was the plan was looking for some input on that end of it you said to change the intake do you mean put the non Vtec one on the new motor or make sure to use the Vtec one
Old Feb 21, 2019
Rodgers18's Avatar
What she the reason for swapping intakes?
Old Feb 21, 2019
moved to correct section. lots of info in this section about what you are trying to do.
oemFTW
Mar 9, 2018 05:35 AM
91LXdriver
Sep 24, 2016 05:06 PM
N1YDP
Jan 20, 2015 05:30 PM
MiamiUgen7
Aug 26, 2005 07:16 PM
trance4mer
Jun 15, 2004 03:01 AM
