Transmission swap post information/Questions about automatic to Manual Transmission swaps
K series 6 speed on d17
Old Jun 18, 2024
Very Strong Boy's Avatar
Very Strong Boy is an unknown quantity at this point
Hey all! I’ve done a bit of digging and I don’t think anyone has made this forum yet. So anyways I’ve been wondering, would it be possible to run a K series 6 speed on a D17A1? I’ve heard of people running the 5 speed on the K series motors, and the RSX 5 speed is almost identical to ours AFAIK. So since my input shaft bearing is about to turn into a claymore, would it be possible and feasible to put a 6 speed in? I’d rather not run into input shaft bearing issues further down the road again lol.
Old Jun 18, 2024
BrotatoChip's Avatar
Super Moderator
Re: K series 6 speed on d17
Only if you want to K swap at the same time. You cannot mount a K series transmission to a D series engine. D series engines are on the driver side while K series is on the passenger side. Meaning a K series transmission mounted to a D series would have the outputs in front of the engine. You'd also have 1 forward gear and 5/6 reverses. This is skipping over all the issues with actually getting it mounted to the engine as well.
RSX 5 speed is almost identical to RSX 6 speed. The D series 5 speed is more similar to B series.
Old Jun 20, 2024
GolNat's Avatar
Prelude Owner
Replace the ISB.
make sure the timing belt has been done.
enjoy the mpg.
BrotatoChip
Transmission
Jul 5, 2022 06:21 AM
judas009
Oct 1, 2012 09:18 PM
bluestreak14
Sep 17, 2010 08:46 PM
Civicman1988
Engine Swaps
21
Nov 6, 2006 10:29 PM
fixeruper
Oct 7, 2005 10:40 PM
